Old 12-15-2008, 01:28 PM   #1
KartingFool
Member#: 172423
04 Impreza TS
Default coolant leak '04 TS
at first it looked like it was coming from the block, looks more like where the lower hose connects to the block - that connection also looks like the thermostat housing
gonna pull it later today, would be nice to know what im getting into beforehand
pics or manuals appreciated
KartingFool is offline   Reply With Quote
Old 12-15-2008, 02:09 PM   #2
KartingFool
Member#: 172423
04 Impreza TS
help please!
Old 12-15-2008, 02:31 PM   #3
KartingFool
Member#: 172423
04 Impreza TS
last coolant change was 2 months/5k ago - system was flushed with 50/50 water and vinegar for a few min, then rinsed 3x
refilled with peak global and subaru conditioner
to me the recent coolant flush and change is incidental and the leak is likely due to the colder weather, associated heat cycles, and 90k mi
started leaking yesterday, its a steady drip and leaves a big puddle... arrrrrrrrg
Old 12-15-2008, 03:04 PM   #4
KartingFool
Member#: 172423
04 Impreza TS
the thermostat housing seems an unlikely place to spring a leak
can anyone confirm the lower radiator hose on a N/A 2.5 goes to the thermostat??
Old 12-15-2008, 03:20 PM   #5
KartingFool
Member#: 172423
04 Impreza TS
will be heading out to do this in 45 min....
Old 12-15-2008, 03:47 PM   #6
dunk
Member#: 15359
It's possible you could a leaking water pump seal.
Duncan
dunk is offline   Reply With Quote
Old 12-15-2008, 03:54 PM   #7
KartingFool
Member#: 172423
04 Impreza TS
Duncan,
you made me cry
Old 12-15-2008, 08:24 PM   #8
MasterKwan
Member#: 98961
2003 WRX
Yeah, water pump is right above it. I'd get it pressure tested and see where the water comes out.
Old 12-16-2008, 08:15 AM   #9
KartingFool
Member#: 172423
04 Impreza TS
Default my subie is bleeding!
didnt try working on it in the dark..
leak is much worse today, have topped it off 2x now - about half a gallon each time
agre, sounds like it needs a new water pump - 90k replace the timing belt with it?
Old 12-16-2008, 08:26 AM   #10
dunk
Member#: 15359
Yes,
Also replace the thermostat and timing belt tensioner.
Duncan
Old 12-16-2008, 10:00 AM   #11
KartingFool
Member#: 172423
04 Impreza TS
Duncan, think the flush and use of non-subaru coolant helped the seal fail?
Old 12-16-2008, 10:21 AM   #12
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Highly doubt it.
As mentioned, if you pull the pump to change it, might as well do belts (AC, PS & Timing) and timing belt tensioner as they all have to come off to do the water pump.
Getting it pressure tested first is a good idea so you know first. It could be a cracked thermostat housing, water pump shaft seal, water pump O-ring/gasket, or even a HG leak.
As to replacement water pumps, I use brand new Bosch pumps with great success and very inexpensive compared to OEM. Do a new thermostat as well.
Old 12-16-2008, 11:40 AM   #13
KartingFool
Member#: 172423
04 Impreza TS
Thanks, Charlie
heading to my local dealer now primarily for a parts estimate, will also see what they charge for the pressure test/repair
Old 12-16-2008, 02:29 PM   #14
KartingFool
Member#: 172423
04 Impreza TS
Default estimate
$450 parts, $550 labor for water pump, belt, tensioner, thermostat, gaskets
ouch, a bit higher than expected, and absolutely cant pay for that now
would be nice if i could replace only the pump and defer the rest, from what i can tell, thats not a good idea
looks like ill be riding my bike a lot until i can afford all the parts
Old 12-16-2008, 05:38 PM   #15
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
you shouldn't need a new tensioner, did they quote that before even looking at it? get a quote somewhere else.
Old 12-17-2008, 08:59 AM   #16
KartingFool
Member#: 172423
04 Impreza TS
yarrgh - no, the dealer hasnt seen it yet
masterkwan - thanks, am taking it to my local dealer (herndon) for a pressure test tomorrow
Old 12-17-2008, 03:59 PM   #17
KartingFool
Member#: 172423
04 Impreza TS
Default non dealer parts
same parts list - $450 at the dealer - from advance auto parts
Goodyear Gatorback Timing Belt
Part Number: 4030 $64.99
Beck/Arnley Timing Belt Tensioner
Part Number: 0241281 $57.99
Cardone Water Pump
Part Number: 571308 $50.99
Stant Thermostat
Part Number: 14147 $8.99
anybody used these parts?
Old 12-17-2008, 04:18 PM   #18
KartingFool
Member#: 172423
04 Impreza TS
Default complete list?
Goodyear Drive Belt Idler Pulley
Part Number: 49029 $35.99
Stant Thermostat Seal
Part Number: 27286 $2.59
roughly $220 or half the price of the dealer parts
Old 12-18-2008, 11:36 AM   #19
KartingFool
Member#: 172423
04 Impreza TS
Default confirmed by dealer
water pump
Old 12-19-2008, 10:39 AM   #20
KartingFool
Member#: 172423
04 Impreza TS
Default Paul Bros. Subaru, Herndon, VA
They did the pressure test while i waited, determined the water pump failed and gave me a reasonable quote of $550 just to replace the pump, another $100 to have the timing belt replaced
Much to their credit, although very busy, they did eval while i waited and in under 30 min and didnt try to rape me for extra parts...
i purchased a water pump, belt, thermostat and gaskets from them for around $200
havent changed a timing belt on a subie since the late 80's
Old 12-21-2008, 06:53 PM   #21
KartingFool
Member#: 172423
04 Impreza TS
Default fixed
6 hrs to replace the water pump and timing belt!
compressing the tensioner proved to be the greatest challenge.
thanks to jonniebravo for allowing me to work in his garage (and did much of the work himself!)
'04 TS gauge cluster in '00 RS? p1fan Interior & Exterior Modification 2 02-12-2004 07:49 AM
'04 TS wagon suspension upgrades? Peter.Lombardi Brakes, Steering & Suspension 16 11-06-2003 02:53 PM
New guy with a few questions about his new '04 TS wagon Peter.Lombardi Newbies & FAQs 11 10-28-2003 06:03 PM
coolant leak, but without the leak iloveturbos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 03-30-2003 12:30 AM
Any info out on the '04 TS yet? Daz Newbies & FAQs 16 02-21-2003 04:43 PM
