North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 12-15-2008, 01:54 PM   #1
03WRX_Rich
Member#: 64660
2003 WRX
Silver & Dirt
Default Coolant dripping from oil filter?
I just looked under my car and found coolant has been dripping off of my oil filter on to the plastic engine cover below. Not a lot, but enough to leave a small stain on the driveway. I smelled coolant after some spirited driving a couple weeks ago, but couldn't find anything.
Checked the oil and it's clean (water free). Any ideas of where this might be coming from? Could it be the infamous radiator crack just traveling to the lowest spot on the car?
too windy to sit around with the hood up like a big sail. Any help would be appreciated.
03 WRX stage .5
regular maintenance on all fluids
Rich
03WRX_Rich is offline   Reply With Quote
Old 12-15-2008, 02:09 PM   #2
Cone Klr
Member#: 73072
02 wrx, 04sti
WRB squared!
Default coolant
the small hose about 2-3inches long connecting the oil cooler to the coolant passage in the block. It is just above the oil filter sandwiched against the block. it has two snap clamps with little guards on them to protect the hose. in my professional experience after thousands of miles and thousands of heat cycles the snap clamps fail to hold enough tension to seal the fitting. replace hose and reuse snap clamps or for piece of mind replace with traditional hose clamps you can tighten after a while to retain seal.
Cone Klr is offline   Reply With Quote
Old 12-15-2008, 02:10 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
you've probably got a radiator leak
very very common on the 2002-2003
Old 12-15-2008, 02:58 PM   #4
03WRX_Rich
Member#: 64660
2003 WRX
Silver & Dirt
Thanks Clone & Jamie. Doesn't antifreeze show up under black light? May be time to clean out the garage and search for the culprit. Now who has a black light....wait, don't answer that.
If it is the water line to the oil cooler, can I get away with just replacing the clamp with a worm-screw type, or should I replace both fittings and the hose itself?
The car has 57K, so hoses are coming up on the checklist in the near future.
Old 12-15-2008, 02:58 PM   #5
03WRX_Rich
Member#: 64660
2003 WRX
Silver & Dirt
Old 12-15-2008, 03:10 PM   #6
hulslander87
Member#: 172791
2006 impreza 2.5i
RBP
i think it is additives in oil, or that you can add to the oil, that show up under black light
hulslander87 is offline   Reply With Quote
oil dripping from oil pan..... jaironsti Built Motor Discussion 4 04-30-2010 12:37 PM
Oil dripping above oil filter... Acrdys Service & Maintenance 6 09-05-2008 10:25 PM
Built 257: Coolant dripping from motor mount... ExecNav Built Motor Discussion 2 10-19-2007 10:11 PM
coolant leak - from oil filter? Penphoe Normally Aspirated Powertrain 24 06-14-2004 03:40 PM
Leaking Oil from oil filter/oil cooler AustinSTi Normally Aspirated Powertrain 3 01-08-2004 12:42 AM
