Old 12-15-2008, 06:45 PM   #1
idrinkdiesel
Member#: 130770
Default Lower control arm
Do I need any special tools to remove the lower control arm off a 02 bugeye? Is it a job the the dealer should do? @600$ I kinda like to do it myself save some rubies....
idrinkdiesel is offline   Reply With Quote
Old 12-16-2008, 01:17 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
$600? you can spend less than that in tools. you could use a breaker bar, impact wrench....ball joint separater. search.
Old 12-16-2008, 02:08 PM   #3
avk
Member#: 17252
'06 WX8
59E
Just remember that the pivot bolts and sway bar link bolts should be torqued with suspension at normal ride height, so as not to stress the bonded rubber bushings.
avk is offline   Reply With Quote
WTB: 02 WRX Pass-Side Lower Control Arm, Knuckle, Rear F&R Lower Arms AdamRX Private 'Wanted' Classifieds 10 04-04-2006 11:28 PM
Aluminum lower control arms? profkirby Brakes, Steering & Suspension 4 03-06-2002 02:14 PM
STI alum lower control arms installed alfriedesq Brakes, Steering & Suspension 0 07-07-2001 03:33 PM
MRT Lower Control Arm Mounts STORER Brakes, Steering & Suspension 7 02-18-2001 01:02 PM
