Old 12-15-2008, 07:09 PM   #1
bnaccs
Member#: 197473
Default Maple syrup smell
My 08 OBS has 4,000 miles on it. I notice a maple syrup coolant smell when the car has been ran for a long time. My wife's 06 Outback XT has the same smell after it is good and heated up. The temperature gauge on the 06 always stays right below the middle and has never gone up. The 08 does not have a gauge so I don't know. Is this normal?
bnaccs is offline   Reply With Quote
Old 12-15-2008, 07:36 PM   #2
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
smell inside of the car? Could be a leaking heater core.
Zac86 is offline   Reply With Quote
Old 12-15-2008, 08:36 PM   #3
bnaccs
Member#: 197473
The smell is on the Outside of both our Subarus. We smell it in the garage, it is not in the vents when the heat is on.
Old 12-15-2008, 08:38 PM   #4
gte123v
Member#: 114481
2006 Sti
take it in for warranty service, you probably have a small crack in the radiator.
gte123v is offline   Reply With Quote
Old 12-15-2008, 09:09 PM   #5
keidori
Member#: 193211
Default same smell
Ive got a 93 gc8, and ive got the same smell, I fully cleaned the engine and STILL cant find the source of the smell.
keidori is offline   Reply With Quote
Old 12-15-2008, 09:12 PM   #6
Troganin
Member#: 115770
2007 2.5i Wagon
Did someone say pancakes?
But serously, id bet radiator.
Troganin is offline   Reply With Quote
Old 12-16-2008, 08:44 AM   #7
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
"(1) SMELLS LIKE: MAPLE SYRUP
WHEN: After the engine has warmed or possibly even after it's shut off for a few minutes.
THE CULPRIT: Coolant containing sweet-smelling (but toxic) ethylene glycol is leaking from somewhere. It could be coming from a radiator or heater hose, a failed intake manifold gasket or cylinder head. It might be coming from a leaky radiator cap or the radiator itself, especially if you smell it outside the car. A strong odor inside the passenger compartment probably means a bad heater core."
From: http://www.popularmechanics.com/how_...e/2423551.html
Kevin Thomas is offline   Reply With Quote
Old 12-16-2008, 11:57 AM   #8
bnaccs
Member#: 197473
Both the 06 Outback XT and the 08 Outback Sport have had the smell since the day we drove them off the lot. There are no visible leaks on either car. I even clean and dust off the engines from time to time. This only happens after the engines have been ran for an hour or more and are nice and warmed up.
Old 12-16-2008, 01:09 PM   #9
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
is your overflow tank too full?
Old 12-16-2008, 04:50 PM   #10
bnaccs
Member#: 197473
The overflow tank on both cars are exactly where they should be. I've checked it.
Old 12-30-2008, 03:29 PM   #11
2.5impreza
Member#: 93983
ever find an answer to this question? I have the same problem...
I am going to change my rad cap today to see if the problem persists
2.5impreza is offline   Reply With Quote
Old 12-31-2008, 03:28 AM   #12
2.5i
Member#: 112986
N/A Cam'd & Cornfed
DOM TUNED 06 Impreza
The smell of coolant could be several different problems all of which the dealership should take care of. I would take both cars to the dealer asap. FYI the water temp gauge in the outback is a dummy gauge, it stays at a certain point. This means that the water temp could be at 5 (for example this is just a meaningless number) then the temp could move up to 15 but the needle will never move from that spot until lets say it raises to 30. I would just keep that in mind. The 08 and up Impreza's have a similar thing but its in a light more like the Toyota's, when the car is cold you will see a blue light and a red light when the car is overly warm and off when the car is normal.
2.5i is offline   Reply With Quote
White Smoke and maple syrup smell commin from engine, HELP Walkerf16 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 05-16-2009 01:01 AM
01 Impreza 2.5 smells of maple syrup (antifreeze) SnowSurfer Service & Maintenance 7 01-24-2007 06:25 AM
Maple Syrup Smell ScubieNewbie Tri-State Area Forum 19 01-18-2006 02:32 PM
My pee kinda smelled like maple syrup, and now I have a craving for pancakes... Cjchaps Off-Topic 30 10-06-2004 04:36 PM
Real Maple Syrup Vs. Synthetic Maple Syrup [27] Off-Topic 21 11-14-2003 09:51 AM
