Old 12-15-2008, 08:28 PM   #1
Screwbal
Member#: 196946
2007 Wrx limited WRB
07 FXT WRB,'15 model S
Default CEL P0420 + shift RPM question (5th to 6th)
So I've only had my 04 STI for a bit over a week now so I'm still getting used to the beast In that week + a couple days I've thrown my CEL almost every day. I had the code pulled and it was P0420. Depending on responses a trip to the dealership is around the corner but posting this question here first.
What RPM/speed do you shift from 5th to 6th? My previous car was a BMW which had more torque so I just always shifted low and was in the highest gear possible. I've noticed when I throw the CEL I've ended up being in 6th gear at 60MPH or just below (maybe 55mph or so by mistake).
Am I just lugging down the motor thus causing the CEL because of my habbit to be in the top gear on the freeway or does this sound like a problem with my O2 sensor? The car only has 31K miles on it so I highly doubt its the CAT thats the problem which leaves me thinking its the O2 sensor.... Or maybe my driving thats at fault
Thoughts?
Screwbal is offline   Reply With Quote
Old 12-15-2008, 08:51 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
it's just that the ECU performs the catalyst efficiency check at that particular cruising RPM
nothing to do with your shift habits
the most common cause of that code is running a catless aftermarket downpipe - if your car is stock then yes a failing cat is the 2nd most common
UkNuck is offline   Reply With Quote
UTEC Stg2 w/ cel P0420. CEL in utec is turned off wrx_nooblet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-15-2005 04:36 PM
CEL P0420 - "Cat efficiency" question Faulk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-05-2005 11:14 AM
CEL p0420 question WimpWgn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-22-2005 06:21 PM
CEL P0420 questions WimpWgn Service & Maintenance 0 02-21-2005 07:02 PM
Shifting From Neutral to Reverse and 5th to 4th xfactor834 Transmission (AT/MT) & Driveline 21 10-18-2002 01:30 PM
