Old 12-15-2008, 11:10 PM   #1
Enphenate
Member#: 179301
Default Hitting 150,000 maintenance time
hey guys im about to hit 150k miles and i was wondering what type of maintenance i should do to my 2000 2.5rs
i have a p0052 CEL but i dont know what to do about it
i just recently:
- reflashed my ecu
- changed my valve cover and spark plug gaskets
- changed spark plugs & spark plug wires (i still get misfire CELs though)
- changed my slave cylinder and bled the system (need to change my master but theres these two little screwes that i dont have the proper tools for)
i am planning on
- changing my oil
- changing my rear diff fluid
- flushing my coolant system (if it isnt too hard)
what else should i maintain with my car or what should i check with it? what type of bushing/parts should i change around the car as well?
thanks a lot
Enphenate is offline   Reply With Quote
Old 12-16-2008, 01:13 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
tranny fluid. there's a website out there for all recommended maintenance. tech.subaru.com or similar to it. mileage isn't a direct indicator of what you should do, how were those miles spent? You can always run some seafoam or BG44K thru it.
Old 12-17-2008, 04:39 PM   #3
BOFslime
Member#: 23845
2015 FLAT SIX
Maintenance Schedule of 2000MY Federal Specification Vehicles
Follow standard 30k interval service items. Check your seat belts for fraying, etc. Some stuff will depend on the last time you did them. But I would replace nearly all fluids, Engine, Tranny, Diff, Brakes, Coolant.
BOFslime is offline   Reply With Quote
Old 12-17-2008, 09:39 PM   #4
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
My seatbelts are fraying.....Honda used to say that they (and most other manufacturers) have "unlimited mileage" warranties on seatbelts....they replaced the belt, retractor, and buckle on my '86 Honda with like 390K miles....for free!
Think Subaru does this?
JamesWilson2 is offline   Reply With Quote
Old 12-18-2008, 08:33 PM   #5
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Yes, they should if it's more than surface cosmetics.
bulwnkl is offline   Reply With Quote
Old 12-20-2008, 08:55 PM   #6
Ekeenan86
Member#: 155493
1999 Legacy Outback
I would recommend changing all your fluids as BOFslime mentioned. When you go to change your coolant it would be a good idea to change your hoses and thermostat. Also change the fuel filter and pcv valve if that hasn't been done in a while. All easy maintenance you can do yourself and its inexpensive.
Ekeenan86 is offline   Reply With Quote
Putting Turbo Kit around 100,000 or 150,000 miles? voteforpedro18 Newbies & FAQs 19 02-20-2010 08:54 PM
150,000 mile maintenance on 2k2 ts, any help would be appreciated danfranklin6 Service & Maintenance 3 11-18-2007 09:30 PM
150,000 mile self service scoobydrew06 Service & Maintenance 10 03-13-2005 02:39 AM
150,000 bucks simwahWRX Mid West Subaru Owners Club Forum -- MWSOC 7 11-11-2003 11:12 AM
Impreza owners: how many over 150,000 miles? Italian Stallion General Forum Archive 10 01-20-2001 12:11 AM
