Old 12-16-2008, 09:46 AM   #1
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
Default hopefully just a battery, need a legacy diagnosis
My fiancee has a 2000 legacy gt. It has a little over 100,000 miles. ANyways the car drives just fine (minus the bad cv boot).
Anyways up here in Washington State, its been 20 degrees all week and getting colder. So here is the story for yesterday
I took my car to Les Schwab for a tire alignment. She picked me up and we went shopping, went to eat, etc.
Then she dropped me off @ Les Schwab, she went to get gas, I left there and went home
She calls me 10 min later and says my car wont start. I said Ill be right there and get down there.
When I get down there, her car seems like its going to start but then shuts off. The clock was off but the light door indicator was on so I pretty much had a feeling it had to be the battery.
I hooked up the jumper cables to her car and it fired right up. After leaving there, we both drove to blockbuster and afterwards, her car started up just fine.
Later in the night about 4+ hours later, I started her car up to check and it fired up just fine. Also she left the house at 5:15am this mourning and it started up fine she said
Was this just a fluke or is there something more going on either with the car or battery?
Thanks for your input and quick diagnosis.
-Daniel
Super_HKS is offline   Reply With Quote
Old 12-16-2008, 11:00 AM   #2
grafton
Member#: 187936
07 WRB STi
your battery could be on its way out, run it to advance / auto zone and they can check the battery in car, plus have them check the altenator while they're in there.
not the most accurate but helpful
grafton is offline   Reply With Quote
Old 12-16-2008, 11:42 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
+1.
If the battery is over 4 years old and possibly giving trouble, it may be time to replace it.
Have you checked the water in the battery recently? If it's low, refill with distilled water (I use the drain off from my dehumidifier in the basement, filtered of course).
The battery could be getting weak, and she left a dome light on while shopping. That could be enough to drain it down.
You can check your own battery/charging system with a DC voltmeter.
Car off overnight, battery should be ~12.8+ volts DC.
Engine running low/mid idle, battery should be ~13.4+ volts DC.
Engine running high idle (2500RPM+) the battery should be ~13.6+ volts DC.
BTW, I was in Lynnwood for business the other week. Sorta on the SW side of town on rt 99. Also stopped at a site in Bothell while out there.
Old 12-16-2008, 04:51 PM   #4
Super_HKS
Member#: 154434
Originally Posted by Charlie-III View Post
+1.
Cools
Lynnwood is pretty nice. Its a wee bit cold this week. Low 20's all week and gonna snow tomorrow and thursday. Thats pretty rare for Wa state.
Thanks for your help guys.
Old 12-16-2008, 09:04 PM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Originally Posted by Super_HKS View Post
Cools
Soooo.....what happened?? Was it the battery or something else.
Need help with diagnosis - transmission slipping? brianbot5000 Transmission (AT/MT) & Driveline 2 01-21-2009 05:42 PM
Need help in diagnosis. Clutch? Flywheel?..other? smittypac Transmission (AT/MT) & Driveline 8 04-10-2008 06:13 PM
Need Hi amp alt or just a battery??? B2004WRX Car Audio, Video & Security 0 02-10-2006 12:18 AM
Need help on diagnosis fedrex Brakes, Steering & Suspension 0 07-03-2004 04:00 PM
my car (or hopefully just my battery) is dead! etam Legacy Forum 17 01-22-2002 10:01 AM
