Old 12-16-2008, 03:23 PM   #1
hefcat
Member#: 151666
2006 WRX STi - Stg 2
SGM
So I was replacing my brake pads on my 2006 Subaru WRX STi because the stock ones were shot after 50k. I purchased the Hawk HPS brake pads and began my installation. I installed the driver side pads with no problems at all but when I began the installation on the passenger side I came across a major problem I think. Oh and these are the front brake pads I am replacing.
I have taken a few pictures and they can be seen at the following link.
http://picasaweb.google.com/hoeflm/S...y=1Bk2N48oyd0#
The brake cylinder cannot be pushed bake so I cannot install the pad. It looks like that seal is broken. Can this be replaced? If so will I be able to replace it or is it easier for me to tow the car to a shop? Or maybe I am doing something wrong whatever the case may be I cannot install the inside brake pad.
Any insight/help is greatly appreciated.
Hefcat
hefcat is offline   Reply With Quote
Old 12-16-2008, 04:54 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
that looks like the outer dust seal / boot - it's not an actual hydraulic seal
replacing it is not a big deal and can probably be done on the vehicle however if you can't press the piston back it suggests that it's been torn for quite a while and brake dust / dirt has got in and seized the piston into the bore - was the car pulling under braking? can you see it move when you press the pedal? (re-fit the caliper before trying that else you may push the piston right out of the bore which WILL require a complete rebuild)
UkNuck is offline   Reply With Quote
Old 12-16-2008, 04:55 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ya need to rebuild that caliper
Old 12-16-2008, 05:21 PM   #4
hefcat
Member#: 151666
SGM
How much will a complete rebuild cost and is that warranty item or is it associated with regular maintenance? Also I did not notice any pulling while braking.
So if I am going to have this caliper rebuilt should I just take the whole care to a shop or take the caliper off and have it separately rebuilt? If that is the case how would I go about removing the caliper?
Old 12-16-2008, 05:23 PM   #5
hefcat
Member#: 151666
SGM
Also how does something like this happen without any notice? The reason I ask is because all of the seals I have on the front pistons look pretty worn.
Old 12-16-2008, 09:38 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
if it is still under warranty....take it---the car....to the dealer have them deal with it
Old 12-16-2008, 09:47 PM   #7
hefcat
Member#: 151666
SGM
I actually talked to a dealer today they said the brembo calipers are only covered until 36,000 miles which I guess sucks to be me.
Old 12-20-2008, 03:54 AM   #8
WRXdonkey
Member#: 105437
20xx STI
OBP/ICM
bump, wtf did you do? And why'd you wait until 50k to swap em? Did the wear indicators never make a sound prior to then?
Not trying to be harsh or critical, but I've got 29k on my pads and I always drive the car very very easily unless I'm doing HPDE or AutoX (not too often).
WRXdonkey is offline   Reply With Quote
Old 12-20-2008, 11:10 PM   #9
magnum2066
Member#: 158586
2009 WRX
Pearl White
If you are handy save the money by buying a caliper rebuild kit and call it a day. As for having someone else rebuild them have a shop give you a quote.
magnum2066 is offline   Reply With Quote
Brake/Suspension help, please! scvkurt03 Brakes, Steering & Suspension 5 04-02-2008 12:45 PM
brake line help please rexmertz Brakes, Steering & Suspension 1 07-20-2006 11:29 PM
Brake Problems...help please haberkorn Newbies & FAQs 19 10-07-2005 12:16 AM
Wiring for 3rd brake light help please MrBlonde Interior & Exterior Modification 5 09-28-2005 04:01 PM
Creaky brake noise!!! Help please! ghostfoot7 Brakes, Steering & Suspension 0 09-22-2004 03:13 AM
