Old 12-17-2008, 03:10 AM   #1
bigislandracing
Member#: 153403
Chapter/Region: HIIC
2004 wrx sti
sti blue
Default Broke wheel studs
Hay everyone, I was wondering why I keep breaking my wheel studs on my front right side. Tire size 255 35 18 on Nitto Invo's Ive changed all the studs and lug nuts. Any help would be great. Thanks
bigislandracing is offline   Reply With Quote
Old 12-17-2008, 03:46 AM   #2
Crawdads
Member#: 30907
SWP GDB-G
Are you still using the factory lugnuts?
How hard are you torquing them down?
Crawdads is offline   Reply With Quote
Old 12-17-2008, 04:22 AM   #3
bigislandracing
Member#: 153403
2004 wrx sti
sti blue
Yes,
I am using stock lug nuts.
Tork is 80 pounds.
Old 12-17-2008, 06:12 PM   #4
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
i had a similar problem on my old accord.... the front right brakes were dragging causing heat buildup. the studs would break when i undid the the lug nuts.
dantastic is offline   Reply With Quote
Old 12-17-2008, 07:19 PM   #5
Daishi00
Member#: 78952
2005 WRX
CGM
Originally Posted by bigislandracing View Post
Tork is 80 pounds.
Part of your problem is right there. Spec is 72.
Also don't torque when hot...only when they are cool.
Daishi00 is offline   Reply With Quote
Old 12-17-2008, 08:01 PM   #6
vividwrx13
Member#: 66402
2005 STi Ver8
Yes,
Tork is 80 pounds.
i do 65lbs on my sti
vividwrx13 is offline   Reply With Quote
Old 12-18-2008, 03:23 AM   #7
bigislandracing
Member#: 153403
2004 wrx sti
sti blue
Thanks for the info guys I will try to re torque at 72 pounds. I did replace rotors and pads. I don't feel any dragging on the breaks. Any other info?
Old 12-18-2008, 05:42 AM   #8
Crawdads
Member#: 30907
SWP GDB-G
change the lugnuts....some of us who change wheels a lot notice that the stockers can gall up and bind to the studs causing breakage.
This and over torquing (or when hot) are the most common causes.
Old 12-18-2008, 03:05 PM   #9
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Do you thread by hand? I never use pneumatic anything on my wheels. On/off by hand, torqued by hand, but esp. threading back on by hand. Also, for some applications as noted the OEM lugs will bind due to how they sit on the wheel.
tazswing is offline   Reply With Quote
Old 12-19-2008, 12:52 AM   #10
beanbeanbean
Member#: 132935
02 rwx
round
stock rims?
beanbeanbean is offline   Reply With Quote
Old 12-19-2008, 11:45 PM   #11
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
Be careful. What ever you do, make sure you solve the lug breaking problem. Hyphymoment had his lugs snap off when driving on the freeway. (not a nice situation) Are you by any chance running wheel spacer?
cpunlamd is offline   Reply With Quote
Old 12-20-2008, 03:23 PM   #12
bigislandracing
Member#: 153403
2004 wrx sti
sti blue
My rims are gram light. I use torque wrench to. I will order new lugs any suggestions on what kind of lugs to order,and I picked up studs from Napa.Is there after market studs that are better quality? Thanks for the info on tighting when hot,cause I have tighted at autocross when hot.I will be sure not to do that any more.So you guys don't think it's wheel bearings.How do you check wheel bearings?Does the tire have to be on to check for play?No wheel spacers are being used.
Old 12-20-2008, 03:27 PM   #13
bigislandracing
Member#: 153403
2004 wrx sti
sti blue
I did notice when I put Whiteline 27-29 front sway it started breaking.But my friends run the same setup with no issues.Could that be why?I don't think so but I figured I throw that out and see what you guys think. Thanks
broke a wheel stud..help MixeD_MenacE Tire & Wheel 6 04-23-2005 07:33 AM
Wheel stud broke off rear drum ScoobySnackZ Service & Maintenance 3 12-08-2004 05:09 PM
Help. Broke a wheel stud Lil'Blue Tri-State Area Forum 6 09-30-2004 11:46 PM
Broke a REAR wheel stud, how do I fix it? BrysImpreza Forester Forum 12 03-07-2004 04:23 PM
Just broke a wheel stud - whose car am I co-driving at CART event tomorrow? Patrick Olsen New England Impreza Club Forum -- NESIC 6 06-30-2002 02:18 AM
