Old 12-17-2008, 08:07 AM   #1
cribbie
Member#: 184505
2003 WRX
Sonic yellow
Default Subaru Cylinder Head Info+ Specs
Hello, does anyone know if there is a link on NASIOC or anywhere else that states all of Subaru's cylinder head specs? ie: combustion chamber, and valve sizes etc etc?
I am more interested in the specs for Turbo application heads like:
WRX
STi: if they changed anything from year to year
Leggy Turbo phase 1 (ej22t)
Thanks for your help!
Cheers..
cribbie is offline   Reply With Quote
Old 12-17-2008, 01:11 PM   #2
Maxwell Power
Member#: 190729
That's really a lot of data.
If you tell us exactly what you are trying to figure out, we could probably point you in the right direction.
For starters, give us a range of years and a displacement or casting number.
For example, the STi in the USA is 2.5L and therefore would not be the same as a JDM STi.
Here's some data:
B25 casting (04-06 USDM STi) 36mm intake, 32mm exhaust 57cc chamber.
D25 casting (06-07 USDM WRX) 36mm intake, 32mm exhaust 50cc chamber.
S20 casting (02-05 USDM WRX) 36mm intake, 32mm exhaust 49.5cc chamber.
You can see that the displacement for the engine is in the casting number:
D25 = 2.5L
S20 = 2.0L
Maxwell Power is offline   Reply With Quote
Old 12-17-2008, 06:02 PM   #3
cribbie
Member#: 184505
2003 WRX
Sonic yellow
Thanks for that info....
Specifically I am looking for:
USDM STi specs ( 04- current)
USDM WRX specs (02-05)
JDM STI 2.0L spec
Old 12-17-2008, 06:46 PM   #4
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
JDM STI 2.0L spec
I too would like this info. But I do know that there was a change during the V7/V8 change over. The Spec C V7 Heads were "big ports" while the rest of the V7's were the ?same? (I think) as the current WRX casting. Where all Ver. 8 heads are "Big Port" but I have no idea if there was any change in the chamber volume or valves used.
Rasmusson14 is offline   Reply With Quote
Old 12-17-2008, 08:16 PM   #5
cribbie
Member#: 184505
2003 WRX
Sonic yellow
I will try to use my "telekinesis" powers to call on Maxwell Propulsion to answer this question!!!!
Old 12-17-2008, 08:27 PM   #6
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
A "search" works just as well, these should help.
Old posts from the "sponaugle"
WRX/STI/JDM Head specs
http://forums.nasioc.com/forums/showthread.php?t=630797
07 head info
http://forums.nasioc.com/forums/show....php?t=1413998
I also found these:
Stock Cam spec's
http://forums.nasioc.com/forums/showthread.php?t=419230
And my personal favorite and nothing to do with the OP's question:
"Boohaahaa - Now that, my friends ,is a turbo! " from 2004
http://forums.nasioc.com/forums/showthread.php?t=674602
Jeff Sponaugle has always been infront of the curve
mick_the_ginge is offline   Reply With Quote
Old 08-14-2011, 12:51 PM   #7
ddrule5
Member#: 291362
how much can i mill off a 2006 2.5 v25 head?
ddrule5 is offline   Reply With Quote
FS:CT-2003 Subaru Wrx 2.0 Cylinder Heads/ New STI Head Bolts 98SubbyLeg Engine/Power/Exhaust 10 11-12-2011 10:42 PM
2.0L cylinder head torque spec pattywomp Newbies & FAQs 1 02-04-2010 02:11 PM
New Subaru OEM Left Cylinder Head Subaru STI 04-05 rs-scooby Engine/Power/Exhaust 4 04-27-2009 07:20 AM
subaru cylinder heads TimBeeno Private 'Wanted' Classifieds 2 09-27-2007 11:45 PM
Ported Spec C cylinder heads (pics) MJU1983 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-27-2003 01:07 AM
