Old 12-17-2008, 09:45 AM   #1
Mr. Quick
Member#: 73496
2005 STi
Crystal Gray
Default Terrible Bucking and Losing Power - Please Help!
I have a 99 impreza 2.5.
The car starts and revs just fine. But when I take off at low speed and place the car under load between about 1700 to 2900 RPM the car bucks and fights me to gain speed. After about 2900 the car seems to mellow out and become normal again. Any ideas?
Mr. Quick
Mr. Quick is offline   Reply With Quote
Old 12-17-2008, 09:53 AM   #2
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
check ur plugs replace w/ new ones ,drive around for a few minutes ,the pull them & see if any one looks different than the others , @ least you will get an idea which cylinder is giving you problems
sense of nature is offline   Reply With Quote
Old 12-17-2008, 11:17 AM   #3
Mr. Quick
Member#: 73496
2005 STi
Crystal Gray
thanks for the input. However, I don't think it is Plugs as the last 5 minutes of my drive the car drove 100% fine. I think it might be related to the MAF. Please people chime in! I encourage responces!
Old 12-17-2008, 11:28 AM   #4
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I don't mean to sound rude, but you have an STI and this is the Normally Aspirated forum.
On a helpful note, it does sound like it could be a dirty MAF.
chazly413 is offline   Reply With Quote
Old 12-17-2008, 12:02 PM   #5
Mechie3
Member#: 120152
Originally Posted by Mr. Quick View Post
I have a 99 impreza 2.5.....
Mechie3 is offline   Reply With Quote
Old 12-17-2008, 12:29 PM   #6
1337Impreza
Member#: 151432
1998 2.5 RS
Arcadia Green Machine
1337Impreza is offline   Reply With Quote
Old 12-17-2008, 12:57 PM   #7
Mr. Quick
Member#: 73496
2005 STi
Crystal Gray
I have 2 cars. My STi is in the garage getting work done to it.
I love my RS. This is the 1st trouble I've ever head with it. Please continue to chime in.
Old 12-17-2008, 01:16 PM   #8
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
does the 99 have a map or maf? I forget. how many miles on the engine? have you noticed that the bucking is at a certain throttle position or RPM? You can try checking the TPS. When was the last time the fuel filter was replaced? Also look at spark plug wire connections.
Old 12-17-2008, 02:27 PM   #9
Mr. Quick
Member#: 73496
2005 STi
Crystal Gray
Fuel filter is good replace 5k ago. Yes does have MAF and I'm leaning toward that. Bucking is at about RPM not any specific (around 1700-2900) I'll look at wires but they are new as well. 120k on engine.
How do I check TPS?
Bucking and loosing power red02wrxwagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-10-2008 03:39 PM
How to Lose Weight, Please Help!! STI_Jaguar Off-Topic 51 11-26-2006 05:16 PM
EGT's spiking and losing power VaScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-05-2006 04:05 PM
engine squeaks and loses power momentarily... what's going on? Poe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-11-2005 03:24 AM
