Old 12-17-2008, 01:11 PM   #1
benham84GL
Member#: 174081
Default P1514 code, swap
So I've swapped a 99 2.2L into my 85 GL wagon and am just workin' out the last bugs. Put ~3000 miles on it so far. Still doesn'y idle correctly, only code besides some fuel/emissions stuff is a P1514 code. Signal 3 low input, IAC. The signal comes from the IAC to the ECM, why would the value be low?? Engine came from a legacy AWD auto, any suggestions? Thanks for any help, I know there's some experts out there on this subject.
benham84GL is offline   Reply With Quote
Old 12-17-2008, 01:13 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
maybe you need more grounds. maybe the iacv needs cleaning/replacing.
Old 12-17-2008, 01:49 PM   #3
benham84GL
Member#: 174081
ooohh crap, gounds, i hadn't thought about that-good call! people have warned me about grounds on these swaps. I've cleaned the IAC, I'm thinking about removing the throttle body this weekend to clean it too, i think I ground things first, though, this code has been intermittent. I get it like 99% of the time, but sometimes runs w/o the 1514, and idles/runs correctly. Thanks so much for the idea!!
Josh
STi swap wiring question BMXspears Subaru Conversions 7 06-04-2010 02:32 PM
[DI$COUNT CODE INSIDE] Formula Drift runs "The Gauntlet": Round 3 - Wall, NJ PostRelease Tri-State Area Forum 0 05-28-2010 12:59 PM
'99 2.2L swap, P1514 code benham84GL Subaru Conversions 4 12-16-2008 05:05 PM
'99 2.2L swap, P1514 code benham84GL 'Old School' Subaru Forum 2 12-16-2008 12:32 AM
Motor codes, ecu codes, swap problems... sti-zy wagon Subaru Conversions 34 12-19-2005 09:09 PM
