Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 12-17-2008, 01:45 PM   #1
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Default 08 STI snow set-up ordered
So, I will let y'all know how it runs and fits when I get them on. Found the smallest rim I could that still indicated it would fit. Going to be 17X7 running 215/55 Hankook icebear W300 (V-rated). According to all the numbers they should be fine.
I will update this post next week once they are situated.
tazswing is offline   Reply With Quote
Old 12-31-2008, 11:57 AM   #2
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Well, after the delay with all the weather the rims and tires have arrived. I am going to pick up a rim and mount it to check for sure the clearance before having the tires mounted. I would otherwise just drive the car over but it is on jack-stands due to the sale of the OEM rim/wheel combo. Tire place said if for some reason the rim does not fit that they will exchange them.
Crossing fingers...
Old 12-31-2008, 12:40 PM   #3
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
i've encountered several 17x7's that fit the sti brakes and even leave huge amounts of brake clearance versus the factory wheels (what i'm using currently for snows). I run 225/45/17 Hakka 2's, with significant studdage, and i love it. Makes for better snow driving when the roads are bad enuf not to drive my Civic.
I just hope those 55 series give ya enuf clearance under the fenders. I am only slightly lower than stock (jdm STi pink springs), and i really pack the snow up in there, and have to clear it out every few days since i don't have a heated garage to melt it every night.
If only someone could find some 16's some day that clear the stock Brembos.
neko is offline   Reply With Quote
Old 12-31-2008, 04:02 PM   #4
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
ha! that would be some serious casting!
I test fitted the rim with no tire. The fit is fine, so now the issue, possibly more that the clearance to the fender (up top) to is the clearance to the spring-perch with the tire on. I will post a bunch of pics when it is all said and done. I will try to get the camera inside to shoot all the major clearance issue spots.
Old 01-01-2009, 02:48 PM   #5
DJSuperSoul
Member#: 120004
2xx8 STI
grey
you will rub on the inner fender andy, at least that is my thoughts after reading the above
DJSuperSoul is offline   Reply With Quote
Old 01-02-2009, 12:15 AM   #6
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
it will be interesting to see. old (oem) radius = 12.9" new 13.2"; side-wall 3.9" vs 4.7". F/R one side bolted on...still on jacks...damn rain.
Old 01-02-2009, 05:14 PM   #7
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
They fit by a hair. The issue is just before full lock. The fender liner has this rib running its length which is where the near hang-up is. But no rubbing while turning at full lock so I am happy.
I went to take pics and my battery died (in my camera that is). Bummer since i went home at lunch to do this since there has been a nice break in the rain/snow today. I might even shoot a vid of the wheel turning in there
Rims: MB Boost (20lbs), 17x7 +38
Tires: Hankook icebear W300 (V-rated): 215/55
Old 01-03-2009, 06:09 PM   #8
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Default Photos!
First here is the over-all look:
Here is the rib in the back that makes them "just fit":
Straight-line clearance up front:
Caliper Clearance:
Slightly smaller surface area against the rotor:
Behind the wheel clearance:
Old 01-03-2009, 06:10 PM   #9
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Just barely clearing up front when at/coming into full lock:
Old 01-03-2009, 08:45 PM   #10
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Finally you get to drive your STi again!
Some of the pics are too zoomed in to really tell whats going on. But the last pic looks like a spacer whould help.
RS_to_WRX_swap is offline   Reply With Quote
Old 01-03-2009, 08:48 PM   #11
Snow Drift
Member#: 75071
4 Train - Subway
Past: 05, 08, 11 Red WRXs
Should of just bought 215/45/17 instead of gigantic 55's
Old 01-04-2009, 04:39 AM   #12
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Next time...
http://www.miata.net/garage/tirecalc.html
Before you talk.
Old 01-04-2009, 01:31 PM   #13
Snow Drift
Member#: 75071
4 Train - Subway
Originally Posted by RS_to_WRX_swap View Post
Next time...
Before you talk.
...uh? His 55's are too tall and hes going to rub. If he bought 45's he would have more clearance. I don't need calculators to tell me that.
Old 01-04-2009, 02:14 PM   #14
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
What the op bought is less then 1/3" closer to the fender. What you said is .6" smaller then stock. Thats changing the gearing a fair amount and puts more miles on your odometer then you are driving. Not the best thing if you care about resale value. However the shorter gearing might help performance. My point is 55 series tire is not that tall, or " gigantic", on a 215 width tire. Remember the "55" is a ratio of the width. I don't think his issue is from tire diameter, instead i think the issue is wheel offset. I haven't seen it in person, so this is just a guess.
Old 01-04-2009, 02:36 PM   #15
Snow Drift
Member#: 75071
4 Train - Subway
The stock rubber is 245/45/18...If he used 215/45/17 the height of the tire would be the same. He is now using a 55 tire. That is too tall to fit. Even the WRX only uses 205/50/17.
I don't think anyone cares about the speedo or odometer readings.
Old 01-04-2009, 04:28 PM   #16
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
245/40/18 are the OEM size.
I have used and continue to use both the wheel size calculator and off-set calculator to spec this set-up and my pending summer 17x8.5 set-up. And just because you get all the numbers working does not mean it will for sure work under the car unless someone has done the exact set-up. And as pointed out, I might try a a 45 next time which will change from OEM the speedo another 2%.
Old 01-04-2009, 04:33 PM   #17
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Wow, i don't think you could fit anymore incorrect information in one post. Stock rubber with the 5 spokes is 245/40/18.
A 245/45/17 and a 215/45/17 DO NOT HAVE THE SAME HEIGHT. The middle number is not a unit, it is a ratio of the width...broken record.
I hate being the dick on nasioc, but you are either a troll, or a complete moron. BTW if the stock rubber was 45 series then he put on what you suggested the difference would be over 2" in diameter.
Old 01-04-2009, 04:45 PM   #18
Snow Drift
Member#: 75071
4 Train - Subway
You've been a dick since your first post quoting me. All I said was that he should of gotten 45 series tires which still would be smaller in diameter than his 55's and he wouldn't have his current issue of them rubbing. You however, decided to use insults, so thanks for adding to the nasioc stereotype.
Your insulting post should of never been made and none of this would of happened. I was correct in my 1st post, regardless of the following posts which didn't take into account that he was switching from 40/18 to 45/17.
Old 01-04-2009, 07:26 PM   #19
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Easy boys, easy.
No rubbing. The last test will be four adults in the car and if it rubs it will only be just before full lock.
Old 01-04-2009, 07:53 PM   #20
Daishi00
Member#: 78952
2005 WRX
CGM
The 55 is NOT the issue. .3" taller is not causing any problems. it's a wheel offset issue. Your suggestion is to run a smaller tire than stock height which will negatively affect both his speedometer and odometer.
Daishi00 is offline   Reply With Quote
Old 01-04-2009, 08:01 PM   #21
Snow Drift
Member#: 75071
4 Train - Subway
Who cares about the speedo being off by a few MPH? If the wheels are rubbing at full lock he is going to wear the tires down or damage the suspension. Who runs the same size as stock? The WRX came with 205/50or55/16's back in 02, no one runs that still.
Subydude sells Torques w/ e35 for 17's on an 08 STI.
Old 01-04-2009, 08:11 PM   #22
Daishi00
Member#: 78952
2005 WRX
CGM
OMG, you really are dense aren't you? 0.3" is NOT what would be causing a rubbing issue, which the OP is not having.
Secondly you want to keep the same final diameter, which is going to vary between the width and the sidewall height as it's a RATIO. Do you understand this?
Old 01-04-2009, 08:16 PM   #23
Snow Drift
Member#: 75071
4 Train - Subway
So if its not the taller tires, he just needs a better offset. ok.
Old 01-04-2009, 09:14 PM   #24
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Thus far, it is NOT rubbing.
And speedo/odom. are indeed not my concern. Maintaining as close to stock size to keep the suspension geometry as close as possible is which in effect accounts for the speedo issue.
As for the off-set the rim comes in +38 and +48. I found out about the +48 after ordering. Called the place I ordered from and said are you sure the +38 offset is the way to go? They said yes.
The +38 retracts the wheel by only 2mm while a +48 retracts by 12mm (obviously). So visually the +38 is going to look nicer with the fender flairs keeping the tires looking like they are closer to the OEM position. With the larger offset the tire would be pulled in more and likely, I feel, would cause more issues.
I think idealy with the design of these rims would be the following:
215/50R17, 17x7 +38. This way we get the 2mm tuck in with the off-set, and only a .2" difference in radius however, it would be .2" smaller rather than .3" larger. So, after I kill these tires (which should not take long since they are snows) I will try that aspect ratio set-up and things would be very sweet from there.
Luke sells the Dunlop SP Winter Sport M3 in this size which are the snows I have on my WRX and love. It will be interesting to compare the Hankooks but now I am thread jacking my own thread!
Old 01-04-2009, 10:30 PM   #25
Daishi00
Member#: 78952
2005 WRX
CGM
Don't worry, only one guy kept saying you were rubbing. The rest of us got it
A +48 would never fit with a 7" wide wheel and clear Brembo's...not a chance in hell, so +38 is the only option you have. That unfortunately has all sorts of compromises because of it though
TW New 08 Sti Brake set up Rat^3 Suspension/Brakes/Handling 21 07-10-2010 06:48 PM
WTT 08+ STI Brake set up for 18's or... Rat^3 Private 'Wanted' Classifieds 1 02-17-2010 07:05 PM
08 STi -- Custom set of KW Clubsports Stinji SCIC Private Classifieds 1 12-24-2008 03:35 PM
*Special Closeout!* VOLK LE28N 18x9.5 +42 for 08+ STi - Last set!! InjectedPerformance Wheels/Tires 11 12-02-2008 02:18 PM
Project Mu BBK for 08 STI now Availible for order! SpeedElement Suspension/Brakes/Handling 3 08-12-2008 08:18 PM
