Old 12-17-2008, 04:05 PM   #1
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Default Off-set question
So, I can't wrap my brain around this. I am looking at some 17x8.5 Enkei RPF1s 5x114.3 +38 for my 08STI for sale by a local. Tirerack has these for sale for this car but the off-set is +45. That seems like a substantial difference in off-set and I am inclined to say that the +38 will not work.
Any tips on making this determination aside from fitting them up?
Thanks.
tazswing is offline   Reply With Quote
Old 12-17-2008, 04:16 PM   #2
tsispyder97
Member#: 59230
97 legacy wagon
white
really? less than 1cm change wont work?
seriously, get your damn tape measure out and look.
its a 7mm difference in outer positioning. not rocket science
tsispyder97 is offline   Reply With Quote
Old 12-17-2008, 04:44 PM   #3
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Ah, your right. It's not rocket science, it's wheel off-set science.
I don't have the rims, I am contemplating purchasing them making using a measuring tape difficult.
08 STi comes with a 18X8.5 rim and these are 8.5 meaning that YES, a "1cm change" might make a difference.
I guess dealing with people like you is still better than crawling back to a seller saying will they give me my money back for making a mistake.
Old 12-17-2008, 04:56 PM   #4
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
tirerack will typically recommend a "safe" offset, almost guaranteeing that you won't rub. +38 is more aggressive than +45, and will probably look better. However, those 7mm might cause rubbing on the body depending on suspension mods, alignment, and tire size.
All in all, 8.5" +38 isn't THAT aggressive for a STI... Heck, I'd run that on my wagon, but I have stiff suspension and adjustable camber...
dantastic is offline   Reply With Quote
Old 12-17-2008, 04:57 PM   #5
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
http://www.1010tires.com/WheelOffsetCalculator.asp
With the same width rim, I am looking at moving the rim location out by 17mm. Tirerack shows a +45 but with a 8" rim (for the same model rim) which translates into extending the rim out by only 4mm and gaining 16mm from the strut housing. So back to the tape measure above, I am going to assume if I add 17mm to the location of the stock wheel, that is where I can expect the the 8.5 by +38 to land the tire.
Old 12-17-2008, 04:59 PM   #6
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Thanks for that. Now I need to look up the handling benefits/compromises of moving the location of the tire in relation to the suspension.
Old 12-17-2008, 05:19 PM   #7
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....not a direct answer to your application but perhaps a good starting point to get the noodle thinking about various aspects:
http://www.miata.net/garage/offset.htm
It doesn't really discuss the benefits or drawbacks but it may help open some doors to finding answers during your research.
Kean is offline   Reply With Quote
Old 12-17-2008, 05:29 PM   #8
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
aren't the RPF1s a 17x8.5 +40mm?
the wheel tire rack shows is the 17x8 +45mm.
reason being is the +40mm will rub unless the proper modifications are done to the rear fenders and ride height matters as well.
where as with the +45mm 8" wheel there aren't any issues with a 225/45/17.
as for the 8.5" +40mm you can get away with a 245/45/17 on an 08 most likely but you do run the risk of rubbing on the rear fenders depending on your ride height.
if these are for winter wheels going a little narrower wont hurt performance and you'll gain some well needed clearance.
when looking at wheel size you can't ignore the tire. 90% of the time the tire is wider than the wheel.
some good articles here.
http://t3hclap.com
WRX8XB is offline   Reply With Quote
Old 12-17-2008, 05:29 PM   #9
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Thank you. "scrub radius" is a new term for me. I am familiar with the term and concept of scrubbing speed when it come to racing. Seems though that unless someone has really done the math with the suspension geometry of a given application you can really only tell if a different offset/rim width will fit vs. adding/take away performance.
Old 12-17-2008, 05:47 PM   #10
WRX8XB
Member#: 45323
there are ranges of what fits and what doesn't, those also concern Scrub radius.
in short if you have to do Excessive work to make it fit and you have more room between your strut/tire then you did before you could've made a better choice.
Old 12-17-2008, 06:39 PM   #11
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
not sure all the different variations. They are advertised as 17x8.5 with +38 and after PMing with the person they said that info was taken off the rim so I have to believe it is correct. This webpage has that size listed minus the off-set: http://wheelweights.net/
http://t3hclap.com
Old 12-17-2008, 10:17 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the +45 hit the calipers
the +38 dont
Old 12-18-2008, 12:31 AM   #13
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
the +38 dont
Thanks! I miss read the post, and the offset is 30 which is a little too much for me. 38 and would have made an offer
Old 12-18-2008, 12:58 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
the 45's clear the 'subaru' 4-pots but not the brembo's
off set question for Tenzo R mach 10 with brembo deuce106 Tire & Wheel 2 08-09-2007 09:48 AM
PRODRIVE Questions regarding off set fitment for 04 STi asianwebmaster101 Tire & Wheel 18 11-19-2005 09:26 PM
Another STI Off-Set question?? rubelcon Tire & Wheel 2 06-13-2004 01:03 PM
quick! need wheel off-set and lug config for a 2000 impreza 2.5rs wnut Bay Area Impreza Club Forum -- BAIC 3 05-14-2001 11:42 AM
rim width, off set??? need help littleblue Brakes, Steering & Suspension 3 05-01-2001 12:31 AM
