Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 12-17-2008, 05:56 PM   #1
gtbensley
Member#: 167448
2013 2013 wrx hatch
Plasma blue pearl
Default Knock Sensor? What should I do?
After the ice storm we just had I went and started my car and it threw a check engine light. Started driving and was not running very well so I stopped and shut it off. Started the car again a couple minutes later and it ran fine but the code was still there. I pulled the codes and they were for cyclinder one and two missfire and a malfunction with the knock sensor. What should I do? Where should I start? Replace the sensor? Thanks for the help
gtbensley is offline   Reply With Quote
Old 12-17-2008, 08:42 PM   #2
Kooter2.5
Member#: 98876
00 2000 2.5rs/blue
2004 WRX STI/silver
If you clear the codes do they come right back? If the Knock sensor comes back on and misfires don't replace the sensor. Either way replacing the sensor wouln't be a bad start, torque it to the correct specs. Is the car still having drivablity problems?
Kooter2.5 is offline   Reply With Quote
Old 12-17-2008, 08:49 PM   #3
gtbensley
Member#: 167448
2013 2013 wrx hatch
Plasma blue pearl
The code has not come back, I have probably driven over 200 miles since I cleared it, the car drives just fine, no problems what so ever. Where is the sensor located on the engine? It only has one correct?
Old 12-17-2008, 09:02 PM   #4
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
OBD2 makes some problems SUPER easy to fix. It's like the answer key, dude.
If the car starts running like crap and the OBD2 says is because of a knock sensor, then what do you do? Change the knock sensor...
bl_easy is offline   Reply With Quote
Old 12-17-2008, 09:13 PM   #5
Kooter2.5
Member#: 98876
00 2000 2.5rs/blue
2004 WRX STI/silver
When looking down on the motor it is on your righthand side(Left bank of the motor) bolted onto the block kind of under the rear intake runner. It's a very basic device, to bad they still cost almost a Bill!
If the code has not returned, then I wouldn't sweat it til it comes back on. Which code was it for the KS?
Old 12-21-2008, 12:51 PM   #6
fornetti14
Member#: 103771
'00 Impreza 2.5RS
Knock Sensor is an easy fix. I think mine was $80 at Autozone - one 12mm bolt holds it on and it's right on top near the drivers side.
Last edited by fornetti14; 01-05-2009 at 07:37 PM. Reason: Yep, it's a 12mm (originally thought it was 10mm)
fornetti14 is offline   Reply With Quote
Old 01-05-2009, 06:05 PM   #7
supernick77
Member#: 145122
1999 99 lgt, 86 brat
black, lt blue
Default 12mm
its a 12mm
supernick77 is offline   Reply With Quote
Old 01-05-2009, 07:15 PM   #8
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
if you ever need a hand im just up the road
watchunglava is offline   Reply With Quote
Old 01-05-2009, 09:53 PM   #9
suzuki4life
Member#: 72706
2002 RS 2.5
RBP
give it some time.
if the knock sensor is activated from bad conditions (in an excessive way) you can get false readings.
You could very easily got water in your fuel, in the intake stream somewhere or the ecu is just glitching.
Knock sensors aren't cheap (close to $100) so I would avoid replacing it unless there are no other options.
suzuki4life is offline   Reply With Quote
Old 01-27-2009, 04:05 PM   #10
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
www.ClintonRacing.com
sorry to bump an oldish thread -- Is there any tips/secrets/cautions to installing a knock sensor? I read through the online service manual. It just said torque down to XX ft/lbs and make sure the wiring is pointing in the right direction.
generalee69 is offline   Reply With Quote
Old 01-27-2009, 05:54 PM   #11
bape-ape
Member#: 136009
96 RapeWagon
Ugly
Thats it, Super easy.
bape-ape is offline   Reply With Quote
Old 01-27-2009, 05:56 PM   #12
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
Alright cool, thanks. It is just a mini-load cell isn't it? I wasn't sure if it needed any sort of special handling.
Thanks again.
Old 05-05-2009, 03:07 PM   #13
MilkManX
Member#: 53378
2006 Impreza 2.5i
Steel Grey
Is it easy on a 98 Impreza L ?
Thanks!
MilkManX is offline   Reply With Quote
Old 05-05-2009, 06:30 PM   #14
fornetti14
Member#: 103771
'00 Impreza 2.5RS
Yes, it's super easy. One bolt and a wire connector and you're done. It's sitting right on top of the motor towards the drivers side.
Old 05-06-2009, 08:14 PM   #15
MilkManX
Member#: 53378
2006 Impreza 2.5i
Steel Grey
Impreza GC8
Thanks everyone. I got the part today and will be putting it in very shortly here.
Its all fixed now!
You guys rock!
Still getting P0325 CE even after replacing knock sensor. What next? Sean Normally Aspirated Powertrain 21 02-11-2012 03:05 PM
02 WRX. 105K service. What should I do and how much should I pay? st000 Bay Area Impreza Club Forum -- BAIC 6 10-12-2008 04:34 AM
Testing Front OEM O2/AFR Sensor... What Should It Read? TDQuiksilver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-17-2008 08:02 PM
Trespassers... What are they doing? What should I do? markman Off-Topic 102 04-08-2008 01:42 PM
What should I do? What would you do? WiredWRX Southern California Impreza Club Forum -- SCIC 14 08-01-2004 06:08 PM
