Old 12-17-2008, 11:28 PM   #1
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Default Swapping Diffs Between Legacy and Impreza
I've been trying to read up on the VTD center diff used in the Legacy Outback VDC and the auto WRX and had a couple questions that searches couldn't answer.
Is it possible to swap a VTD diff into a manual 5-speed? If so, would it be possible to swap the final drive "ring" to make it work with the rear end?
If I could swap that into a 5-speed, would it stay "locked" in the open position at 45/55?
My main goal behind this is to find a center diff that has a slightly more tarmac friendly setting than the stock viscous 50/50.
subydude is offline   Reply With Quote
Old 12-18-2008, 12:45 PM   #2
DS1
Vendor
Member#: 111780
The VTD in an auto would be like the DCCD in a manual trans.
There are DCCD 5mts from the older GC8's
-Dylan @ DS1
DS1 is offline   Reply With Quote
Old 12-18-2008, 12:51 PM   #3
subydude
Member#: 80649
-Dylan @ DS1
True. I was just looking for something that was more available and at a more friendly price. Something I could throw in for a few hundred dollars and have instant response vs the viscous. The 5-speed car is used for rallyx just in case you were wondering the use of the car.
I also have a Ver 7 non-dccd 6-speed in a different car that has the viscous center that I've been trying to find a better center diff for. In the end it looks like I'll have to swap to a dccd tranny simply because there are no good "preset" options from the factory that don't make it act like a RWD car.
Old 12-19-2008, 12:59 AM   #4
supersuby2
Member#: 161678
2002 wrx
white
You can get the 12 kg center diff for GC and 20 kg center diff for the GD..... they work great over the stock 4 kg units and can be had 400-500 lightly used or 900 new. keeps front and rear axle speeds very close all the time
supersuby2 is offline   Reply With Quote
Old 12-19-2008, 09:00 AM   #5
subydude
Member#: 80649
I've found the 20kg diff, but I haven't found the 12 yet. Where have you seen the 12?
Old 12-19-2008, 12:36 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
the 12kg unit is only for PHASE1 trannies
STi V1-STi Ver4 5spds
the 20kg unit is only for PHASE2 trannies
STi Ver5+ 5spds
The 6spd VLSD center diff is constructed differently. Not the same part.
FuJi K is offline   Reply With Quote
Old 12-20-2008, 07:48 PM   #7
Jack88
Member#: 198032
goodluck
Jack88 is offline   Reply With Quote
Old 12-20-2008, 09:17 PM   #8
supersuby2
Member#: 161678
2002 wrx
white
I thought he is looking for a 5 speed center diff...... rallispec would be worth a try but if you have the phase 2 trans 2001 and newer i believe you will only be able to get a 20 kg center.
Old 12-21-2008, 01:47 AM   #9
subydude
Member#: 80649
I was kind of looking for both a 5-speed and 6-speed option. I wasn't sure if they were different or the same.
The 5-speed is from a 2000 2.5rs so I'm guessing Phase 2. Whenever time and money allows I guess I'll be looking for the 20kg center for it.
Old 12-21-2008, 08:25 PM   #10
supersuby2
Member#: 161678
2002 wrx
white
You will like the 20kg center, it will make the car push more on pavement but can be tuned out with suspension adjustments and will be very worth it on lose conditions......
Old 12-21-2008, 09:52 PM   #11
subydude
Member#: 80649
That's more or less what I figured. The car is mainly going to be used for RallyX, with some spirited on road driving in between. I'll just be running KYB AGX's with some stiff springs and a set of sways. I won't mind if it pushes a little bit on the road as long as it does it's job off the road
Old 12-24-2008, 02:52 AM   #12
supersuby2
Member#: 161678
2002 wrx
white
It will work well off road and wont be that bad on road.... you will like it!
swap diffs between WRX and GX dpjef Transmission (AT/MT) & Driveline 0 07-23-2007 07:29 PM
Downshifting into 1st @ 20+ mph: The difference between a Legacy and Impreza 5 spd annointed Transmission (AT/MT) & Driveline 8 08-27-2002 11:34 AM
anybody know the diff. between GT and OB springs? sybir Legacy Forum 5 05-01-2001 07:10 PM
Thoughts on Diff between 18mm and 20mm bar AllWheelsDriven North West Impreza Club Forum -- NWIC 3 04-30-2001 04:33 PM
Centre diff on the Legacies and Imprezas.. Garvinator Normally Aspirated Powertrain 3 02-04-2001 03:31 PM
Message Board Statistics All times are GMT -4. The time now is 01:24 PM.
