Old 12-18-2008, 12:42 AM   #1
3rdgearpinned
Member#: 131664
Default heat stopped working
97 legacy 2.2
heat worked good last time i needed it about 5 months ago and now it doesn't. The blower works fine, blows air, just the air coming out isn't not hot or even warm. What could it be? do the heater cores on these go out? it's got 180,xxx miles. it's going to be in single digits at night now and heat would be nice...what do i need to inspect? coolant is not low.
3rdgearpinned is offline   Reply With Quote
Old 12-18-2008, 10:33 AM   #2
rkramer
Member#: 118209
2015 WRX Limitec
thermostat stuck open. I'm willing to bet your mileage sucks also recently.
Old 12-18-2008, 06:13 PM   #3
3rdgearpinned
Member#: 131664
I haven't noticed mileage, i don't drive far. I can get 300 miles to a tank, maybe 350, thats all hwy.
How do i check the thermostat?
any good posts to key off of?
Old 12-18-2008, 06:15 PM   #4
3rdgearpinned
Member#: 131664
also...The engine temp gauge works fine, if the thermostat was bad wouldn't it not work propperly?
Old 12-18-2008, 10:20 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
heater core plugged up? when the engine is warm, check the 2 lines on the driver side going to the firewall and see if they're hot.
Old 12-25-2008, 04:20 PM   #6
3rdgearpinned
Member#: 131664
I replaced the thermostat, still nothing. I need double check coolant level.
could it be my water pump? head gasket?
What if I were to remove the thermostat?
I will check the two lines today.
Old 12-25-2008, 05:01 PM   #7
3rdgearpinned
Member#: 131664
it's the headgasket, when i cracked open the rad bleeder on the left of the rad exhaust was blowing out(motor was running)
bummer looks like the car will taken to the wrecking yard.
Old 12-25-2008, 05:05 PM   #8
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Could be as simple as a broken blend door or cable. Look under the dash at the cables fine the one that moves when you adjust the temp knob, make sure its hooked up.
Both heat seats stopped working blah0r Interior & Exterior Modification 5 02-22-2010 09:56 PM
Supertones stopped working... But the horns still work. What gives? RP31 Electrical & Lighting 5 11-23-2007 10:13 PM
heat stops working sometimes hondaeater69 Service & Maintenance 11 12-18-2005 10:26 PM
Weirdness. Horn stopped working, then worked again.... Siper2 General Community 16 11-25-2005 11:45 AM
Heated seats stopped working CletusTheDwarf Electrical & Lighting 4 10-18-2005 05:40 PM
