Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 12-18-2008, 02:11 AM   #1
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
Default Raw Fuel Smell/Leaking Fuel Line on WRX
Went to warm up the car leaving work this morning the cabin smelt fine and when i was pulling down my street and parked in my driveway i smelt fuel, but didnt think anything of it since my dad was warming up his car and could be exhaust fumes. Then smelt it again while the car was idling going thru the McDs drive thru. Went away after driving. Then tonight heading to work I smelt this again and goes away when driving but when idling still at one spot for a bit the smell comes back.
Just got this problem this morning and now researching it through this thread http://forums.nasioc.com/forums/showthread.php?t=131755 .
Have any of you had this problem and have you had it taken care of? if so who did it and were you able to get this covered?
pumpkyn is offline   Reply With Quote
Old 12-18-2008, 03:47 AM   #2
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
i kinda searched on this awhile back i found something about there not being enough back pressure in the exhaust can cause it ill try to find the thread again
blackout801 is offline   Reply With Quote
Old 12-18-2008, 04:13 AM   #3
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
i know about the downpipe thing, i just got back from lunch and it smells like fuel even after having the car fully warmed up. I got back here to work and popped the hood and smelt a fuel odor by the passenger side.
Old 12-18-2008, 11:01 AM   #4
filly peeno
Member#: 150315
2009 Legacy
i also have this smell. only when it is cold
filly peeno is offline   Reply With Quote
Old 12-18-2008, 11:15 AM   #5
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
Does the 04' WRX stillhave the fuel filter in the engine bay? I think that in 05+ they put the fuel filter in the tank, not too sure. If so change that out as well as check your hose lines. As the temp. gets colder the hoses harden, as you drive the car the lines get hot then cold then hot then cold, this flux in temperature can crack hoses and you might find some lines need to be replaced. I have seen a couple of the 02-03 wrx's needing hoses replaced because of this.
Stames_wiltz is offline   Reply With Quote
Old 12-18-2008, 11:23 AM   #6
Kentrik
Member#: 125937
03 WRX I do not
like your tweed, chap.
I've had to replace hoses twice in my engine bay. But it's like a buck for a fuel hose.
Kentrik is offline   Reply With Quote
Old 12-18-2008, 11:24 AM   #7
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
I just had this same issue on my 06. It turns out that it was the roll over valves (2 each on top of the gas tank) that was the porblem. I did have a cel. After the mechanic dropped my gas tank he found that both roll over valves had the stems broken/cracked and was seeping out gas fumes. evidently subaru has had a rash of these and parts are on backorder. I was lucky and mine only took about 2 weeks to come in and about 4 hrs of labor to fix.-john
06AZREX is offline   Reply With Quote
Old 12-18-2008, 11:43 AM   #8
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
My advice.... Don't wmoke in the car
medamullet is offline   Reply With Quote
Old 12-18-2008, 11:47 AM   #9
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
hahaha yeah it used to drive me crazy, almost smelled like an open container of gas sitting in the trunk
Old 12-18-2008, 12:07 PM   #10
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
only when youre stopped as well?
it does have the filter in the engine bay but i checked all the lines and they are tight and show no signs of cracks or leaks. but there are quite a few fuel lines in the engine bay
which hoses?
Old 12-18-2008, 12:08 PM   #11
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
wow thats crazy!
Old 12-18-2008, 03:22 PM   #12
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
There is a fuel line that leaks on the passenger side. its the fuel line that is under the turbo coolant resivour between the 2 intake manifold runners and back a little bit, i just had to fix it on my friends 02 wrx. I had to pull the manifold off and ended up finding a cracked hose on one and also a loose clamp. so i replaced the hose and all the clamps on the fuel rails. took me aboue 1.5-2 hrs.
Im assuming this is the same problem as yours because its a common problem. There is a thread somewhere called "Raw fuel smell log" most everybody has the same problem. But i see you have already found it.
bhhamblin is offline   Reply With Quote
Old 12-18-2008, 03:50 PM   #13
Stames_wiltz
Member#: 143264
2006 WRX TR
Wow BHH you can pull a intake manifold off and put it back on in an hour and a half? Why hasn't Solid hired you?
Old 12-18-2008, 04:21 PM   #14
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
The 2.0L intake manifolds are allot easier than the 2.5L
Old 12-18-2008, 04:27 PM   #15
Stames_wiltz
Member#: 143264
2006 WRX TR
even still, I remember saying with my 05' WRX that it would take the whole day to do the Manifold so he could install my topfeed injectors.
YOUR AMAZING BHH!!!!
Old 12-18-2008, 04:32 PM   #16
Kentrik
Member#: 125937
03 WRX I do not
The fuel filter ones. Both sides cracked, but the front one wore more because the FMIC pipe sorta smashes it.
Old 12-18-2008, 04:38 PM   #17
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
Creep
Old 12-18-2008, 04:50 PM   #18
Stames_wiltz
Member#: 143264
2006 WRX TR
^^^ I hate you
Old 12-18-2008, 04:51 PM   #19
JokerDMX
Member#: 175664
03 WRX
FP Green/Built&Cam'd 2.5L
I was there too It happened
JokerDMX is offline   Reply With Quote
Old 12-18-2008, 07:43 PM   #20
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
Wirelessly posted (Pumpkyns Pymp Wyng: Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 6.12) T-Mobile_Atlas)
hmmm brodizzle I may have to hire you to do that. I called nate wade and they require a diagnostic of 45 and if that is the problem they say SOA should have no problem covering it.
nut I see one clamp I can tighten myself without taking it off but most say the loose clamp is the one that's hidden and faced the wrong way.
oh yeah this is the cars first time in real cold weather since this used to live in san fran til this february. im sorry
Old 12-18-2008, 11:15 PM   #21
AWDBat
Member#: 1983
2008 STi
Dark Grey Metallic
I had this problem with my '02 WRX. It was the fuel rails that needed to be replaced. After that it never happened again... at least while I owned the car. SOA covered it, but I was still under warranty.
AWDBat is offline   Reply With Quote
Old 12-20-2008, 05:03 PM   #22
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
^^^ who did you take it to?
Old 12-20-2008, 06:12 PM   #23
AWDBat
Member#: 1983
2008 STi
Dark Grey Metallic
Larry Miller Subaru.
Old 12-20-2008, 07:31 PM   #24
overlord
Member#: 52186
2005 LGT LTD
Regal Blue
This is a known issue, SOA should cover it.
overlord is offline   Reply With Quote
Old 12-20-2008, 08:14 PM   #25
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
they won't cover it, i asked, but i have done it on ours since i was removing the tgv's anyhow. I can take off and put the manifold back on in about the same time as brody, i also leave off those damn useless brackets too.
car_cursed is offline   Reply With Quote
Raw fuel smell/leak when cold, where did Chicago ppl get theres fixed? MF-DIF Mid West Subaru Owners Club Forum -- MWSOC 74 02-14-2009 05:24 PM
Fuel smell while heater is on. skoobidoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-09-2005 11:08 PM
replacing brake lines on wrx, anything i need to watch out for? wrxracer55 Brakes, Steering & Suspension 8 11-02-2003 10:00 AM
Coolant Leak near Turbo on WRX NewSuby Service & Maintenance 2 03-08-2003 01:21 AM
Goodridge SS vs Stock Brake Lines on WRX ITWRX4ME Brakes, Steering & Suspension 15 12-11-2002 07:23 AM
