Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 12-18-2008, 02:44 AM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Default Weakened wipers - which part to change?
I've noticed my wipers are having hard times working on higher speeds 120+ km/h
I guess the motor is going bad?
Is this the part (behind the strut tower) that needs to be replaced? (just found some random pic, I hope the owner doesn't mind)
also, does it fit from newer GD cars?
Hyper is offline   Reply With Quote
Which wires to change when upgrading ALT MAtwal Electrical & Lighting 0 01-06-2010 05:28 AM
oil pump leak @ 60k..what other parts to change? sonic03dz Service & Maintenance 11 01-06-2009 08:10 PM
sti ra gearset swap in RS, which bearings to change White 2.5rs Transmission (AT/MT) & Driveline 1 03-04-2004 07:17 PM
Which gaskets to change when doing injectors? Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-06-2003 11:06 AM
2nd oil change and which oils to change? makofoto Service & Maintenance 4 12-28-2002 08:07 PM
