Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 12-18-2008, 12:22 PM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default vf39 tooo big?!
well i threw out the VF22 idea and thinking of getting a VF39...
due to twin scroll and people say the 22 has more lag...
will the VF39 be too big for a Ej20g? 94wrx.
and i think i found a solution to that 90 degree angle..
what do u think? good idea? bad idea?
azn0boi04 is offline   Reply With Quote
Old 12-18-2008, 12:25 PM   #2
brumby
Member#: 162631
02 Ford focus svt
I had both,but I think my vf30 was better all around.
brumby is offline   Reply With Quote
Old 12-18-2008, 12:44 PM   #3
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
I have a vf39 on my ej20k and it is stock I put the 39 on the only mod I had to do was bend the oiler hose to make it fit...the screw only goes in one way and it was tough to get it in...also I had to cut a coolant hose a little bit to make it work..I'm running stock boost and I didn't have to have my PFC retuned...boost is great...it starts around 2500rpms...I'm wanting to go to a vf22 but don't know which is better
Cbgrandtheftauto is offline   Reply With Quote
Old 12-18-2008, 01:03 PM   #4
phillepe
Member#: 88856
2007 Sti
on 36's.....
AFAIK the VF22 is a single scroll turbo
phillepe is offline   Reply With Quote
Old 12-18-2008, 01:12 PM   #5
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
If you can run a GT30 on a EJ20 you can run a VF39 no problem . That turbo is small as hell .
ASU is offline   Reply With Quote
Old 12-18-2008, 01:25 PM   #6
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
cool doesn't seem too hard... i think im going to get that VF39 this weekend. and install it... ill be running stock U8 ECU...(11.47psi)
my silly question:
do u hear the turbo spool a lil bit through the exhaust, when u rev tiny bit?
Old 12-18-2008, 03:29 PM   #7
Wanarex
Member#: 173034
any VF turbo will work well the 2.0L motor. and the lag on the vf22 probably would not be as bad as you think. depends on your budget but deadbolt offers some sick options on their 16G with or without the 90 degree inlet. Check it out.
Wanarex is offline   Reply With Quote
Old 12-18-2008, 03:39 PM   #8
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
idk, im just porting my 16g
300 whp isnt that bad you know
JDMFLCL is offline   Reply With Quote
Old 12-18-2008, 04:34 PM   #9
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
16G for small "big" turbo... all day
check the comparison faq... has the most cfm... and I can tell you from experience that it spools yesterday
That vf turbo should spool good though
blkgm8 is offline   Reply With Quote
Old 12-18-2008, 04:38 PM   #10
JDMFLCL
Member#: 180513
Baby Baby C'mon!
sorry for the thread jack, but how good would a PnPed td05-16g be? would it be good @ 18-21psi+650-750cc injectors i.e. ~380-400 crank?
Old 12-19-2008, 04:02 AM   #11
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
well NOW i have my mind set on VF39.... and for the 90 inlet,
im just gonna get a silicone 90 degree elbow, and just some hose clamps..i hope that works.
something like this...
im excited...
whoa i just found this..
this confuses me tho... i dont think they know there stuff... let me know what u think
ebay
Old 12-19-2008, 11:02 AM   #12
suberdave
Member#: 101865
88 GL-10 STi
that is for an EJ207...
will not work on your car...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 12-19-2008, 02:18 PM   #13
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
yeah i thought so....ill just get the turbo installed and i hope it all works out...
im excited
Old 12-19-2008, 04:57 PM   #14
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
That would be a kick ass street turbo... the 750cc injectors are a bit large for the application though. I would run the 650cc... you should definitely reach your goals and be well within the turbo's efficiency range at the psi you stated... You would be smiling alot.
would require engine management though.... You probably know this.
The vf vs 16g is like when the 1g turbo eclipse had the tdo5-14B... then realized it was more that what was needed for the engineered power levels of the motor.... Then switched to a smaller t25 on the 2g car and still met the factory desired power level easily. You only noticed when you turned up the boost that it was not up to task. All day any day the 16g is an "upgrade" over the vf series. Although certain vf are much better than others. check into the deadbolt turbos.
Old 12-19-2008, 06:25 PM   #15
JDMFLCL
Member#: 180513
Baby Baby C'mon!
im running PFC w/ datalogit+hallman mbc
1-2 years from now, itll all be completed
project <$10,000 400chp swapped daily
Old 12-19-2008, 09:02 PM   #16
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
send ur td05h 16g from a ej20g to deadbolt and have the monster port and wheel. you will be happy.
gc8awdsti is offline   Reply With Quote
Old 12-19-2008, 11:45 PM   #17
JDMFLCL
Member#: 180513
Baby Baby C'mon!
im sending it to grimmspeed most likely
Old 12-20-2008, 01:21 AM   #18
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
nah im just getting a vf39...plus i like the sound of the spool.
gets boost @ 2400...
Old 12-20-2008, 02:22 AM   #19
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
vf 39 is NO where near what the td05h is. the 16g is much much better and spool is there to. in my opinion as well with alot of others...the 16g is the way to go.
Old 12-20-2008, 06:46 AM   #20
Ammata
Member#: 155819
2004 Impreza WRX
vf39 is pretty small in my opinion.......and you should actually run some 565cc injectors anything bigger than that would be a bit big
Ammata is offline   Reply With Quote
Old 12-20-2008, 02:08 PM   #21
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
my silly question:
I run 14psi on DD and 16-18lbs racing and thats on stock injectors...Idk about turbo noise in exhaust my blitz nurspec is super loud so all is heard is the rumble
Old 12-20-2008, 02:58 PM   #22
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
my silly question:
haha... sounds like you need that ebay turbo sound whistle for your muffler... not a turbo upgrade.
Nah... I understand what you are saying though... You gotta do whatever makes you happy in the end. Its your car and if hearing the turbo whine in your exhaust is your only desire... go with the vf and put the biggest catless turbo back exhaust you can find on it. You will hear it... even if someone with a 16g owns you from a stoplight... you can catch up at the next red light and say "so.... I bet you cant hear your turbo whistle if you stand behind your car!"
Old 12-20-2008, 03:07 PM   #23
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
okay... I had my fun... Now seriously. You will be very happy with the VF. Just go for it and don't listen to any of us 16g guys. We are a biased bunch because we are probably the more performance oriented guys. That is not the only important thing of owning a car. I have heard the sound of a turbo spooling through the exhaust... It sounds sweet. Kind of like running an open downpipe, but quieter. You will still have a performance upgrade, just not as much as the 16g. Good luck with your car. Sounds like it is gonna be a sick ride.
Old 12-20-2008, 09:11 PM   #24
94 GT
Member#: 193676
94 legacy GT
silver (grey soon!!)
what did the 16G come on stock???? the older STI's??? legacy RS's , the I have a solid deck 20G what turbo came on those old 20G's?????? I tell ya it is like twice the size of the little thing on the 22t!!!! but the turbine is not that much bigger just a little bit! but the compressor is like wayyyy bigger!!
thanx Jesse
94 GT is offline   Reply With Quote
Old 12-20-2008, 09:29 PM   #25
suberdave
Member#: 101865
88 GL-10 STi
my silly question:
if you want to hear turbo spool. just drill a few 1/8 inch holes in your intercooler piping. its a boost leak, but sounds like a loud whistle under boost...
-=Suberdave=-
08 wrx w/ sti mani, vf39 and big tmic, couple issues rexxx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-16-2010 04:31 PM
WTB VF39, Walbro big ol side feeds... AK SloPok AKIC Private Classifieds 14 05-22-2008 02:23 PM
WTB: VF39/34/big 16g, or 18g turbo!!! epyon08 Private 'Wanted' Classifieds 0 05-15-2008 07:17 PM
wtb: 20g -soon to be for sale vf39 and big tmic I3oostedScooby Tri-State Area Private Classifieds 3 12-01-2007 10:32 AM
i might as well do it tooo.... bratmantlz Rocky Mountains Impreza Club Forum -- RMIC 0 05-11-2001 09:58 AM
