Old 12-19-2008, 01:10 AM   #1
aveisone
Member#: 171364
2006 STi
Default 225/55/16 tires on stock wheels?
im looking into buying some new snows since i just had one slashed last night. im lowered on sti struts with sti pink springs. its about an inch drop all around give or take. ive found some nokian tires in 225/55/16 and i want to get them mounted up for this upcoming snow.
heres my question:
is anyone running this setup on their stock 16's with either stock suspension or lowered? any rubbing?
aveisone is offline   Reply With Quote
Old 12-19-2008, 07:08 AM   #2
aveisone
Member#: 171364
2006 STi
any opinions would be appreciated. i know these tires would be a bit wider than stock (225-205=20) by almost an inch.
Old 12-19-2008, 07:34 AM   #3
ShlowShtuph
Member#: 188240
95.5 Impreza
MAaarooooon
If I'm not mistaken wrx came with 205 55 16 right? If so you would want to step the sidewall down a few notches if going to a wider tire. shoot more toward a 225 45 16 Maybe even a smidge shorter than that.
It's a percentage so the wider you go with the same sidewall, the taller the sidewall would be. End result being less acceleration, spedo saying you're going slower than you really are, and being lowered would probably mean clearance issues as well.
I'd say you shouldn't have a problem with the width, I don't have a wrx so I wouldn't swear to this but I had a dsm with stock wheels and 225's. Ask the guys at your local pep boys, ken towery's, walmart auto center, whatever you have local
ShlowShtuph is offline   Reply With Quote
Old 12-19-2008, 07:45 AM   #4
ShlowShtuph
Member#: 188240
95.5 Impreza
MAaarooooon
I just looked at the threads of note for you. There is a tire calculator on there and 225/50/16 should be the closest sidewall to 205 55. Also The 02 WRX has a 6.5 inch wheel (it didn't have 04 listed). DSM's also had 6.5 inch wide wheels. You should be perfectly capable of mounting 225's to your wheels. good luck.
Old 12-19-2008, 07:13 PM   #5
EdHilario
Member#: 137398
2004 Impreza
225/55/16 is oversized. You can try 225/50/16 or stay with the stock size for 04 WRX which is 205/55/16.
EdHilario is offline   Reply With Quote
Old 12-22-2008, 01:44 PM   #6
aveisone
Member#: 171364
2006 STi
i decided against it the 225 was going to be way too wide. i luckily found a set of the same exact snows i had with the exact same wear about 2 hours away, and the seller basically gave them to me. i only replaced the rears and now i have spares.
225/55/16 tires on 03 WRX Wagon w/ stock rims mynameischris Newbies & FAQs 4 05-05-2008 04:03 PM
Picture request: 225/55/16 or 215/55/16 tire on 05 WRX rims gopsu Member's Car Gallery 11 10-05-2006 11:19 AM
195/55/16 tire on stock RS wheel? Will it fit RSblood Tire & Wheel 1 11-28-2005 10:39 PM
FS: Central NY: 4 Bridgestone Potenza 225/55/16 tires speedypete Private 'For Sale' Classifieds 4 01-10-2005 12:54 PM
Do 225/50/16 tires on WRX wheels fit my BF legacy? Dealer Xing Legacy Forum 4 12-10-2002 10:25 PM
