Old 12-19-2008, 02:08 AM   #1
STi_4_life
Member#: 157030
2007 Impreza STi
Default 245/40/17 on 17x8.5 +48 rubbing ?
STi 07
Advan Neova 245/40/17
Rims 17x8.5 +48
Drop 20mm (JDM STi Pinks)
Rear camber 1.3
Will it rub ?
STi_4_life is offline   Reply With Quote
Old 12-19-2008, 09:16 AM   #2
aznguyjac
Member#: 87488
u might be pushing it...
i have 245/40/17 on 17 x 8.5 +50 offset.
i was rubbing my front coilover. i do have 2.0 camber.
forced me to run 10mm spacer on fronts to clear
anyone has input to make it fit without spacer?
aznguyjac is offline   Reply With Quote
Old 12-20-2008, 12:48 PM   #3
STi_4_life
Member#: 157030
2007 Impreza STi
Any other opinions about my setup ?
Old 12-20-2008, 01:32 PM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I ran 17x8 +48 with 245/40-17 and it wasn't close to anything. I think you'll be fine.
Old 12-20-2008, 01:45 PM   #5
chanmanWRX
Member#: 100221
2007 WRX LTD
you'll be fine..jdm pinks arent low.
chanmanWRX is offline   Reply With Quote
Old 12-20-2008, 02:32 PM   #6
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
18x8.5" +48 (245/40/18 RT615 tire) fit on my STi without issues.
I only rubbed in a very tight corner, at the track. And the rubbing was nothing more than the plastic inner fender liner in the front. Suspension at the time was RCE yellows, Ohlins struts, and around 2.2 degrees of camber.
You shouldn't have issues with the 17".
steve is offline   Reply With Quote
Old 12-20-2008, 10:52 PM   #7
Daishi00
Member#: 78952
2005 WRX
CGM
Neova's run pretty wide, but you should still be fine with that offset.
Daishi00 is offline   Reply With Quote
Old 01-11-2009, 03:16 AM   #8
STi_4_life
Member#: 157030
2007 Impreza STi
Little update on my setup.
1) Advan RS 17x8.5 +50 with 245/40/17
2) Advan RS 17x8.5 +50 with 255/40/17
3) Advan RZ 17x8.5 +45 with 245/40/17 GTR face <3 (same fender clearance as #2)
What will fit my car without fender rolling ? Also will RZ +45 offset clear brembos ?
Specs:
STi 07
drop ~20mm (Type RA struts + Arai springs)
rear camber -1.3
Old 01-13-2009, 06:29 AM   #9
STi_4_life
Member#: 157030
2007 Impreza STi
help ?
Old 01-13-2009, 09:33 AM   #10
waktasz
Member#: 86356
2015 s1000r
wheelie monster
They should all be fine.
waktasz is offline   Reply With Quote
Old 01-13-2009, 02:12 PM   #11
Badler
Member#: 133597
You should be fine. Possible rubbing with passengers and turns. It's only like $50 to have your rear fenders trimmed to be on the safe side.
Badler is offline   Reply With Quote
245/40/17 on 17x8 ET48's? fizzak Tire & Wheel 4 01-01-2010 12:25 AM
245/40/17 on 17x8.5 +30? Glenn Hough Tire & Wheel 16 01-16-2009 05:45 PM
Test fit request: 5x114.3 - 255/40-17 on 17x8.5 +48 or 255/35-18 on 18x8.5 +48 mav1c Mid Atlantic Impreza Club -- MAIC 10 10-20-2007 11:46 AM
Wait! I can do 245/40/17 on 17x8s????? DomzWRX Tire & Wheel 8 06-02-2007 02:51 AM
245 40 17 on 17x8 on 05 sedan bigworm Tire & Wheel 8 07-08-2005 09:03 AM
