Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 12-19-2008, 11:21 AM   #1
Drummer
Member#: 74084
Question Trouble to start engine after gaz tank fill-up
I recently change my 2.2L engine on MY99 impreza. New engine is still a 2.2L but come from a 2003A/T impreza, everything is running perfect in any driving situation.
But, when I go to the gaz station and put fuel in the tank (whatever the quantity or grade). I have trouble to restart the engine after. I need to
1. keep the gaz pedal to the floor, crank about 5-6 time then engine starts.
2. keep my foot on the gaz pedal for a 1-1 minute to avoid it to stall and restart to step #1.
Once these to steps are over, the engine is running just like any other car and start without any issue until the next fill-up
No CEL
No special noise
Did you ever see this problem ?
If so, how did you resolve it ?
Thank you
Drummer is offline   Reply With Quote
Old 12-19-2008, 06:47 PM   #2
bmp9422
Member#: 194846
2008 Impreza OBS
Steel/Spark Silver
check to make sure your MAF sensor is position properly.
When installing my intake i had similar problems because my sensor was backwards
bmp9422 is offline   Reply With Quote
Old 12-19-2008, 07:53 PM   #3
2.5GTLegacy
Member#: 111219
Overfilling the gas tank?
2.5GTLegacy is offline   Reply With Quote
Old 12-20-2008, 06:13 PM   #4
Drummer
Member#: 74084
no, that happens whatever the quantity of fuel I put in...
Old 12-21-2008, 09:44 AM   #5
EastsideLegacy
Member#: 58806
1998 RIP Legacy2.5GT
2.2L legacy wagon
I would try replacing the fuel filter before anything then check the pump maybe something is loose on the connections or something funny like that and put some lucas fuel cleaner in there...
I have a similar problem but its not the same... its only when i fill the tank fully it cuts out randomly as i drive at 2000 -3500 rpms but once i get the gas to about 3/4 its fine..
And i have new pump and filter
But good luck buddy
PEace main
EastsideLegacy is offline   Reply With Quote
Old 12-21-2008, 12:34 PM   #6
Skidd
Member#: 1853
GC6 Supercharged
STM
^ I get a similar strange issue. Once I fill my tank to full, for about the next 2 miles or so, my fuel trims go way outa wack and the car sputters just a little while driving due to the fuel trims trying to pull massive amounts of fuel! The STFT goes to -20 to -25% while the LTFT also goes to -25% to -30% with just normal driving. At idle my LTFT usually sits at -18% (I have quite a few engine mods including Delta Cams). But with a full tank I get -30% and the STFT is also way out at about -25%.
But, then after just a couple of miles of driving, it all normalizes!! Can't quite figure out what causes it? The fuel pressure doesn't change. I have a pretty accurate digital Fuel Pressure Gauge that doesn't show any crazy changes. But, it acts like the pressure has sky rocketed. Or like it's sucking fuel in through the evap lines? But, that doesn't seem likely... does it?
So.. my issue isn't the exact same as the OP, but I wonder if it's related? Your hard to start problem could be due to too much fuel, kinda like how my engine also shows it's getting too much fuel.
P.S. I drive a 2000 2.5RS with full IHCE.
Skidd is offline   Reply With Quote
Old 12-22-2008, 05:44 PM   #7
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Same issue. If I shut off car fill tank then start, it will will start then die right away. I take the key out wait 10 seconds and start again just touch the gas after it starts and it will run normal until the next fill.
My car is an 05 STI. Fuel system is stock.
TurboSetch is offline   Reply With Quote
Old 12-30-2008, 04:38 PM   #8
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
I have ready about 20 threads like this now and no one ever seems to figure it out. Sucks.
Firefox/IE take forever to start right after startup... help? zombiefeedingtime Off-Topic 8 07-09-2009 12:02 PM
Car wont start after tank fill up!! SSsleeper96 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-22-2005 10:05 AM
Where to sell engine after swap? (00 2.5rs) nick robinson Subaru Conversions 28 07-11-2003 11:59 AM
Gas Tank Fill up Problem JimsWRXSTI STi Forum Archive 5 06-13-2003 07:34 PM
Trouble opening driver door after window is rolled up wcbjr General Forum Archive 2 03-13-2001 11:31 AM
