Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 12-19-2008, 07:56 PM   #1
Edo Performance
Member#: 70537
Default Project Edo400
PROJECT EDO400
PROJECT EDO400 MADE ITS FIRST DEBUT AT SUBIE INVASION 2008 IN LAS VEGAS, NEVADA ROCKIN THE ALL NEW ZEROSPORTS BODYKIT FOR THE GRB. COMPLEMENTED BY A SET OF BLITZ BRW PROFILES, WRAPPED IN 18 INCH RUBBER, RIDING ON BLITZ COILOVERS, IT WAS EASY TO WHY PROJECT EDO400 STOLE THE SHOW. TO BACK UP HER SLEEK NEW LOOK, EDO IN CONJUNCTION WITH BLITZ PERFORMANCE AND TOMEI POWERED USA DECIDED TO GIVE HER SOME JUICE WITH THE NEW ARMS M7760 TURBO. BUT WE AREN'T DONE YET!!!!! STAY TUNED AS WE TRANSFORM PROJECT EDO400 INTO...
MOD LIST
EXTERIOR
ZEROSPORTS BODY KIT
BLITZ WHEELS
ENGINE
TOMEI ARMS M7760 TURBINE
COBB DOWN PIPE
TOMEI EQUAL LENGTH HEADERS
BLITZ NUR-SPEC R QUAD TIP EXHAUST
BLITZ POWER INTAKE SYSTEM
POWER ENTERPRISE 800CC INJECTORS
BLITZ RADIATOR
SUSPENSION
BLITZ COILOVERS
M7760 VS STOCK
Edo Performance is offline   Reply With Quote
Old 12-19-2008, 07:59 PM   #2
Edo Performance
Member#: 70537
Old 12-19-2008, 11:45 PM   #3
jcovey2.5
Member#: 126195
05 CGM WRXTi
Wagon , 95 Red SVX L
nicely done, cant wait to see it go in person
jcovey2.5 is offline   Reply With Quote
Old 12-21-2008, 11:05 PM   #4
wrblueballs
Member#: 121549
2005 WRX 20G, PPG
kinda want to lick that car....
wrblueballs is offline   Reply With Quote
Old 12-26-2008, 01:03 PM   #5
pana24
Member#: 139487
2006 wrx
aspen white
so sick my goodness that turbo
pana24 is offline   Reply With Quote
Old 12-28-2008, 01:18 AM   #6
amg destroyer
Member#: 124897
STi
It was awesome seeing this car in person. Truly a masterpiece
amg destroyer is offline   Reply With Quote
Old 12-28-2008, 02:10 AM   #7
Edo Performance
Member#: 70537
thanks guys!
Old 01-07-2009, 06:52 PM   #8
Edo Performance
Member#: 70537
Bump!!!
Old 01-07-2009, 08:13 PM   #9
Edo Performance
Member#: 70537
Bump!!!!
Old 01-07-2009, 08:17 PM   #10
phillepe
Member#: 88856
2007 Sti
on 36's.....
Wow! Looking Good!
phillepe is offline   Reply With Quote
Old 01-14-2009, 02:19 PM   #11
Edo Performance
Member#: 70537
PROJECT EDO 400
DAY 1
When we finally got our hands on the new 2008 STI, we all just kind of stared at it for while like it was a spaceship that had crash landed in front of the shop. Sure the wider front and rear fender were a plus, but the hatch took some time to get. Interior-wise up until now, the STi had been fairly simple, equipped with just the bare necessities; basic dash setup and a set of blue alcantara seats. With navigation system, xm radio, and leather trim, we were beginning to think the new STI had lost touch with its rugged, mud-covered roots!!!!
There was only one way to know for sure!!! And within the first 1000 miles, she was already on the dyno. At EDO Performance, we like to use the DYNAPACK chassis dynamometer instead of the roller style dyno for a few reasons. The first and most obvious reason being there can be no tire slip, no rolling resistance, and no chance of the vehicle coming off of the dyno at high speeds. By using a hub adapter, you eliminate variables such as tire temperature, pressure, and traction that can lead to a potentially high margin of error.
Another advantage of using the hub style dyno is the elimination of the ratcheting tie-down straps. Although the use of straps does provide additional traction, the enhancement also changes the rolling resistance of the tire, thus distorting the data further. When speaking about dynamometers, the word “inertia” is thrown around quite often.
Inertia is defined as the resistance to change in a state of motion. Street wheels and tires spinning at high RPM have a large amount of kinetic energy. A large steel drum spinning at the same ground speed has much more inertia. What you end up with, is described by many as the “giant flywheel effect”. By just trying to accelerate the mass of the roller, energy that should be going into the dyno is wasted and a substantial amount of load is then placed on the engine. As a result, the power curve you view on your dyno graph generally looks like a pretty, smooth line. That is because this flywheel effect tends to just smooth over any small, rapid oddities or inconsistencies. Because the dynapack relies on practically zero inertia, the car’s behavior on the dyno can be displayed with much more accuracy and in much higher definition. This is in return however, does yield lower numbers in terms of horsepower and torque.
An initial bone stock base run on the Dynapack gave us 223.5 WHP and 233.4 lbft of torque. It was at that point we realized there was much work to be done.
STAGE 2.5
It wasn’t until we collaborated with BLITZ Performance that Project EDO400 really began to take shape. Initial power upgrades came with the addition of the Blitz power intake kit and quad tip Nur Spec exhaust system. To complement exhaust flow, we also installed a set of Tomei Equal Length Headers. With a quick Motul fully synthetic oil change, zerosports oil filter, and a set of one step colder spark plugs, our Stage 2 Cobb Protune was soon underway.
Up until now, generally what we classified as Stage 2 was just the upgrade of the factory downpipe, catback, and intake system along with supporting modifications like Walbro 255LPH fuel pump and spark plugs. In the graph above we were able to generate 293hp and 322lbft maintaining use of the stock downpipe and fuel pump.
The graph above shows about a 30 horsepower gain that was achieved just by installing the arms turbo charger alone without any additional tuning or larger injectors. We were curious to see what kind of raw power we would gain by simply changing the turbo charger alone on our stage 2.5 setup.
STAGE 3
To complete stage 3 of our EDO 400 Project, we added a catted Cobb down pipe and set of Power enterprise 800CC fuel injectors to really make our new Tomei Turbo scream! A Blitz radiator was also thrown into the mix for some added cooling power! After just a few hours of tuning, we managed to make just under 340 WHP with a whopping 372.9 lbft of torque! This was definitely a surprise! In comparison with our previous Tomei Turbo test car, a 2007 STI, we noticed that the GRB produced significantly more torque, while only sacrificing just the slightest bit of horsepower. Since the 2007 STI test car was also equipped with fuel rails and a larger capacity intercooler, we suspect this may have contributed to the difference in horsepower.
When Tomei designed this unit, they had one goal in mind; design a well match unit that would produce significant gains in horsepower and torque, while maintaining lightening fast response and remarkable drivability through sustained power and boost levels all the way to redline. With this unit, Tomei really hit the mark dead on. When used in conjunction with the Tomei Equal Length Headers, we experienced a smoother power band and absolutely zero fade in power at higher engine and RPM speeds.
Installation was a breeze, as usual with most Tomei Products. The new studs and coolant hard pipes that came with the kit were definitely a nice touch. When you hold this unit in your hands for the first time, the old saying "you get what you pay for" seems like it has never had more meaning than in that very moment. From the Tomei Arms Logo cast into the compressor housing, right down to the neat packaging, it is easy to see the Tomei Powered Pride standing behind this unit. You are not just paying for the name, but over 40 years of unmatched quality and engineering experience.
STAY TUNED!!!!!!!
Stay tuned as we put Snow Performance’s new Stage 3 Boost Cooler methanol injection system to the test. Their new stage 3 boost cooler system claims to utilize a user-friendly, 3 dimensional delivery map that will allow the user to “read and inject according to either EFI fuel injector pulse-width, boost level, or any combination of both. The kit also features an LCD screen that displays boost pressure, injector pulse width %, as well as water-methanol injection percent. The kit includes a high volume 150+ PSI high volume pump, 3 quart reservoir, and two nozzles to cover a wide range of horsepower.
“Why methanol-water injection?” you might ask? Much of methanol’s popularity can be attributed to its ability to resist detonation. Having control over detonation allows the vehicle to make more power through added boost or increased timing. Most injection systems use a 50/50 composition of water and alcohol, with miniscule amounts of water-soluble oil to prevent corrosion of the injection system and fuel system. When water is introduced into the combustion chamber, the air-fuel mixture is drastically cooled, resulting in a substantial increase in horsepower and reduction of heat absorption by the cylinder walls. This added cooling effect allows the engine to run at higher rpm and boost levels without overheating.
Dealing with methanol is not a task to be taken lightly. The slightest malfunction during operation can and will most often result in catastrophic engine failure. For many years this risk has been a dividing factor amongst high performance enthusiast. To dismiss these fears, Snow Performance has developed what they have come to call “Safe Injection”. For an additional $200, users will have peace of mind that their motor is protected in those instances where no injection is present and an aggressive tune is utilized. In the event that no injection is present, not only will an alarm be triggered, the timing will automatically retard and boost levels will be reduced. Snow also offers optional solenoids that allow the waste gate or bypass valve to open in the event of insufficient flow or even failure. The failsafe system also utilizes an overflow alarm for leak detection. Stay tuned for more information as we take project EDO400 to the next level!
Old 02-03-2009, 09:00 PM   #12
Dstretch33
Member#: 157211
2k4 stg. 2 WRX sti
This is a nice build
Dstretch33 is offline   Reply With Quote
Old 03-12-2009, 01:24 AM   #13
xxkunsxx
Member#: 204988
2004 WRX
i just had to change my pants
xxkunsxx is offline   Reply With Quote
Old 07-11-2009, 12:22 AM   #14
englishguy3012
Member#: 147943
2004 Sti 2.5 XTR'd
372whp, Stock block 1yr+
my god looks killer lads
englishguy3012 is offline   Reply With Quote
Old 08-16-2009, 03:45 PM   #15
JAKbauer24
Member#: 137904
looks awsome you guys at edo always come up tops
cheers james
www.scoobyclinic.com
JAKbauer24 is offline   Reply With Quote
Old 08-16-2009, 07:29 PM   #16
Edo Performance
Member#: 70537
hey James, thanks very much. How is your car running?
Old 08-26-2009, 11:16 AM   #17
JAKbauer24
Member#: 137904
Not fully rebulit yet engine ready for the car next week
Will post a pic tonight think you will like it ;-
Old 08-30-2009, 09:12 PM   #18
osborne519
Member#: 193618
02 impreza wrx wag
psm
o.0 i like this very much
osborne519 is offline   Reply With Quote
Old 08-31-2009, 03:01 PM   #19
Edo Performance
Member#: 70537
thanks
Old 09-22-2009, 12:24 AM   #20
BRN09STI
Member#: 219081
2009 STI GRB
How is the blitz radiator treating you? is there noticable gains over the stock radiator?
also what other cooling modifications have you done? thermostat? silicone hoses? fan shrouds? cooling plates?
thanks
BRN09STI is offline   Reply With Quote
Old 11-15-2009, 11:19 AM   #21
Edo Performance
Member#: 70537
The Blitz radiator has brought down the temperature in about 15 to 20degree F during boost. We did silicon hoses only and leave the rest stock.
Old 11-15-2009, 11:22 AM   #22
Edo Performance
Member#: 70537
We are going to move to second stage with this car and rebuilding engine and more to come. Please stay tuned for more update!
Old 11-19-2009, 11:06 PM   #23
SubieFiesta
Member#: 149426
2002 Subaru WRX
2005 Subaru STi & 2000 RS
looks good, but why does the power dive so hard after 5500rpm?
SubieFiesta is offline   Reply With Quote
Old 12-03-2009, 01:31 PM   #24
Edo Performance
Member#: 70537
We need more room to breath on the stock head. Usually upgraded head would help on the top end flow.
Old 03-31-2010, 11:41 AM   #25
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
The build is looking really great guys, keep it up!
Will
GrimmSpeed is offline   Reply With Quote
Project GC8 .... AKA Way to long of a project Cstmboxermotorsports Member's Car Gallery 64 04-10-2008 03:38 PM
No project management....Need easy way to keep track of multiple projects Fach Off-Topic 1 12-06-2006 11:28 AM
Project CASPER.....Complete!.....Project Garfield started jimtweet Member's Car Gallery 67 06-29-2006 01:53 AM
Updated project pics on the 2.4 Ej22 project M3GTR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-22-2005 05:27 PM
Project 2.5 Turbo L Wagon project Complete! yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 6 07-29-2003 04:27 PM
