Old 12-19-2008, 09:50 PM   #1
Knightmare69
Member#: 25039
2005 CGM Stage 2 WRX
SQC 275
Default Aggressive offset and bearings
Can we get a thread going and sticky it regarding flush/aggressive offset wheels and bearings? I tried to search this subject but most of the threads that come up are just people asking if they can use a certain offset and yada yada yada.
I'm not going to lie, I used to be on the bandwagon about running low offset wheels and ruining your bearings but after seeing so many people running this set-up, I have yet to actually read bearings getting damaged.
So for you owners that have low offset/aggressive wheels fitment, can you chime in with the dimensions of the wheels, how long you've been running them and if you are STi or WRX (to see if there is a difference between the bearings) and how your bearings are performing to date?
Knightmare69 is offline   Reply With Quote
Old 12-19-2008, 10:10 PM   #2
chanmanWRX
Member#: 100221
2007 WRX LTD
ib uncle scotty chimes in real soon
chanmanWRX is offline   Reply With Quote
Old 12-19-2008, 10:35 PM   #3
Knightmare69
Member#: 25039
SQC 275
Chimes in about what? If you've seen information on this subject please show me as I've tried to look it up but come up with only what I've already mentioned.
Old 12-19-2008, 10:53 PM   #4
Daishi00
Member#: 78952
2005 WRX
CGM
This low offset craze has only been running around for what a year? Unless they're putting 20k on the odometer it's gonna be a bit before the bearing failures start popping up. Plus, what's the chances that they're going to post that they had a bearing failure
Daishi00 is offline   Reply With Quote
Old 12-19-2008, 11:03 PM   #5
Knightmare69
Member#: 25039
SQC 275
Understandable but the fact is when the craze first started, everyone was adamant that the bearings would fail and to an extent made it sound like it wouldn't take long. Even so, people who may not drive the cars as often must be driving at least in some what metropolitan areas where factors such as potholes and what not affect the wear with that type of set-up no?
Old 12-19-2008, 11:05 PM   #6
ONE_1
Member#: 185180
03 Forester XS
18x9.5 te38 Work Emo CR kais
Its only been a month and i have not noticed anyhting.. I believe So Steezy and a few others chimed in on it in the Aggressive thread. I cant find it though
ONE_1 is offline   Reply With Quote
Old 12-19-2008, 11:14 PM   #7
Knightmare69
Member#: 25039
SQC 275
Well that's why I started this thread. So that we can have a consolidated thread of actual facts from people that run this. Because we have such a divided opinion about this and I think eliminating bandwagon with actual facts is better then having people spew just things that they read or hear.
Old 12-19-2008, 11:41 PM   #8
Daishi00
Member#: 78952
2005 WRX
CGM
You want statistics to disprove facts of physics. If wheel bearings last 100k+ for many people is 50k failures something you would expect? How many of these people are going to keep the car with low offsets for 50k? How many do you expect to say "yup, my bearings died". Nobody said they were going to fail within a few months, or a few thousand miles, but they WILL fail faster than a car running a stock offset.
Old 12-19-2008, 11:58 PM   #9
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Bay Area Impreza Club Forum -- BAIC
Speed Element/Mach III/WheelDude.Com are all down with HELLAFLUSH!!<3<3<3<3 Forever!
Wrong Fitment Crew
Fendyman is offline   Reply With Quote
Old 12-20-2008, 12:13 AM   #10
Knightmare69
Member#: 25039
SQC 275
Yes I understand that but I just think that having real life accounts of how this set-up holds up is beneficial to our community. If you don't agree then obviously that's your opinion and you're entitled to it.
But the point is right now we don't know how long this type of setup lasts before one might start to experience issues. I just started this thread to keep an account of it. If the mods decide that it's pointless then let them delete this thread, it's fine with me.
I can just as easily go and pm members of this setup and ask them how their car(s) are fairing. I just assumed that there were others like me that in their heads asked the same question but were too afraid to ask because of the fear of getting ridiculed on a public forum.
Old 12-20-2008, 12:33 PM   #11
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
The bottom line is that wheel bearings are "wear" items. Like some others have said, chances are you won't get the life out of a bearing on a +30 offset than you would with a +52. That said, it's not going to be as drastic as 50% less lifespan. I guarantee that a track car with stock offset will put more pressure on their bearings than a daily driven hellaflush. A lot of it falls down to one's driving style. Take lot of fast turns? You're putting added pressure on the bearing regardless of offset. One also needs to consider that today's wheel bearings are built well, and in the case of our cars, overbuilt. They can take a few more mm's.
When I had my 02' WRX wagon, I rolled +48 for years. Fast forward to around 30,000 miles, and the car was at the dealer getting warranty work done on the bearings. Sometimes it's the luck of the draw. Like WRX trannies, some blow after a few launches, while others last 100,000 miles on a GT30 turbo.
steve is offline   Reply With Quote
Old 12-20-2008, 03:11 PM   #12
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
I think thats the best answer Ive heard for a while^
Im running 18x9.5 +40 et with a 10mm front spacer
Ive been on this setup since march, on 06 sti hubs. No problems yet. I havent tracked on them yet, and the hubs are used.
scby rex is offline   Reply With Quote
Old 12-20-2008, 03:42 PM   #13
grippy monkey
Member#: 131067
your "stance"
sucks
me...
04 STI
been rolling around on 25mm adapters for over a year (making most of my wheels +21-23)
then switched off to random low offset wheels in the +30-35 range
I drive my car hard, and I do road trips to Vegas and SF from LA often.
I have 54k+ miles right now. The bearings are a wear item as stated. I know some people only get 80k on them. Some people get more or less. Mine show no signs or wear or anything right now. If I get another 10-20k on them I will be happy. If the tradeoff is only 10k miles or so I think that's a very fair tradeoff for being able to have a clean looking car.
It goes the same for the motor. If you are producing 400whp and drive it equally as hard as a stock setup it will go out faster with 400whp.
same as for a clutch, brakes, struts, etc etc
modding is fun... and wearing out items just gives you the opportunity to upgrade and make it better.
grippy monkey is offline   Reply With Quote
Old 12-20-2008, 03:48 PM   #14
jardine
Member#: 119595
2005 forester xt
aspen white
^^^well put josh
jardine is offline   Reply With Quote
Old 12-20-2008, 09:30 PM   #15
Daishi00
Member#: 78952
2005 WRX
CGM
hypa - 05+ STi bearings are designed well, but all WRX models and 04 STi models have much less stout bearings. These will fail sooner and with less stress than the 05+ design even on stock offset wheels.
As for track vehicles, the question then becomes is it a heat related increase in failure rates or offset related. I would hazard a guess to point more towards the former rather than later.
Old 12-20-2008, 10:14 PM   #16
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
I personally don't care about the life of the wheel bearings, or the physics involved (newton). The completely overlooked issue with the wide wheel and the offset that makes it "flush" is found in Geometry. You simply reach a point where the scrub radius can no longer be corrected because the camber adjustments needed to alter the steering axis angle are so ridiculous that the tires cannot perform. Thus the car cannot perform. I am glad that it gets overlooked because that gives folks like me an edge. A properly sorted suspension (calculated, diagramed, and corrected) with components that actually perform in harmony will turn the same lap times with considerably less power. It is simple math, but the " I want it to look like that" crowd obviously don't utilize it. I am not against people doing what they want, just pointing out that for so much talk about performance it seems odd to act to the contrary. You wouldn't need to worry about that extra 100+ whp if you actually sorted out your car. Truth be told most people aren't experienced enough with performance driving (need for speed doesn't count) to actually know the difference. It is more than two cents and wanted or not I tossed it into the pot like everyone else.
UFOpilot is offline   Reply With Quote
Old 12-20-2008, 10:18 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
which is why it is SO ****ING IMPORTANT TO FILTER WHAT IS POSTED
so that the poor stupid bastards that are reading this **** dont get to far ahead of themselves
It is irresponsible to recommend 'excessive' options based on "I do it so it must be ok for everybody to do it".
This mentality(or lack of ) is responsible for MUCH of the that happens on this board and
we all can see that LESS ****ING CONFUSION WOULD BE A GREAT THING
Old 12-20-2008, 10:30 PM   #18
Daishi00
Member#: 78952
2005 WRX
CGM
UFO - excellent point about the scrub radius and camber issues that come about from making these wheels fit. It's a difference between function and form...unfortunately most now only care about the form
Old 12-21-2008, 08:49 PM   #19
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
FWIW, I run 17x7 47 offset with 225x17 semi slicks and15mm spacers (to clear the front Brembos). Camber -3 deg track setting on front, -2 deg Road on front. Rears stay on -2 deg.
I would have run 20 odd track sessions so far over the last 2 years at 15 laps per session - 3.5km tight track - so about 1000km to date.
Bearings just starting to make a low wrrrrrrr now but no big deal. Will probaly change out early 2009.
For me, I went this way to get more front grip and consequent less understeer. The bigger rollbar on the rear also helps. I love the way this car works on the track for me. Yes bearing are maintenance items and replacement every 2-3 yrs is ok by me.
Love this thread.
renhoek is offline   Reply With Quote
where is that aggressive offset thread TheKrazyAsian Tire & Wheel 1 04-27-2009 10:56 PM
Wheel Gallery for the Aggressive offset and size... downsti Member's Car Gallery 13 10-29-2008 11:28 PM
attn: those looking at aggressive offset wheels steve Vancouver Impreza Club Forum -- VIC 69 04-07-2008 04:17 AM
+40 offset and wheel bearing damage? nate.the.great Tire & Wheel 3 10-26-2004 08:21 PM
Offset and Wheel Bearings 19" OZ SLs +45mm Brian Broz Tire & Wheel 6 10-06-2003 02:28 PM
