Old 12-20-2008, 03:39 AM   #1
fastlanerex
Member#: 133391
2004 boosted saleen
white
Default 90k service am i missing anything
I want my car to be tip top before it goes on the dyno to get tuned
okay heres the list of things i have done /plan on doing tell me if i miss anything.
Things I have replaced
fuel filter
spark plugs
fuel pump (walbro)
rear diff fluid
trans fluid
Things I am replacing
pcv valve
injectors
turbo
oil pump (should I do this i am getting some scary low readings. tapped in on oil gally plug) timing belt,tensioner
radiator/hoses
coolant
IACV cleaning it out (new gasket)
Did I miss anything I should do?
What size oil pump should I get its an 04 wrx but i want somthing that flows more volume than the one that comes with my car... and no not a crawford one, thats for my built block.
I read the service faq sections and stickies but figured i would put my list out there
Thanks in advance
Drew
fastlanerex is offline   Reply With Quote
Old 12-20-2008, 01:35 PM   #2
fastlanerex
Member#: 133391
2004 boosted saleen
white
bump..........
Old 12-20-2008, 01:58 PM   #3
VIPGarage
Member#: 113463
02 Subaru WRX
Ol' Blue
wasn't this posted somewhere else too? Could have sworn I replied.
You seem to have it covered. If you are showing low oil pressure i'd inspect your oil and filter for anything that appears to be debris/sludge before doing an oil pump.
VIPGarage is offline   Reply With Quote
Old 12-20-2008, 03:45 PM   #4
fastlanerex
Member#: 133391
2004 boosted saleen
white
yes you did see it else where i accidently posted it in maic when i meant to post it here.
Am I missing anything for a WRX drivetrain into 95 impreza wagon conversion? ruskiyab Subaru Conversions 3 03-17-2004 05:56 PM
New engine won't start. Am I missing anything? burnout555 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-26-2003 05:04 AM
gonna order parts for system...am i missing anything? garie Car Audio, Video & Security 8 04-05-2003 07:31 AM
30k mi. service, am i missing anything? newbie sewbie Service & Maintenance 7 12-24-2002 12:14 PM
