Old 03-30-2002, 12:58 PM   #1
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Question STi transmission swap
No not the new 6-speed What about tranplanting a JDM MY00 or MY99 STi tranny into our WRXs...would it be a drop in? or were the axles, center diff, driveshaft, etc... different on the older STi as well? It just seem that they would be a helluva lot cheap than the $6-8k for the new six speed and can handle more power than our WRX tranny. Just a thought...probably a misguided one at that.
mr2guru is offline   Reply With Quote
Old 03-30-2002, 01:32 PM   #2
XT6Wagon
Member#: 524
04 STi
You will need a rear diff, I bet as the ones I've seen are all 4.111 or 4.444
You might look at the GT-B/B4 RSK trannies as they have a wider gear spacing that while it will make the car slightly slower, will also make the car far more comfortable to drive. Most people if they thought about it would give up a tenth in the 1/4 for vastly reduced highway RPM, and less missshifts on the run itself. The Tight RA box requires constant rowing down the strip which makes for a high possiblity of missing a shiftpoint or missing the next gear.
XT6Wagon is offline   Reply With Quote
Old 03-30-2002, 01:33 PM   #3
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Would be a straight drop in except matching the final drive ratio at the rear diff. Most likely it would be a 4.44 . But you would have to confirm that with your supplier.
Ver.III is offline   Reply With Quote
07 STI Transmission Swap TraviST185 Drivetrain 9 11-06-2008 03:09 PM
05 STi transmission swapped jonpark Transmission (AT/MT) & Driveline 1 09-11-2008 08:40 PM
2004 STI Transmission Swap - EVERYTHING Included rcgservices Drivetrain 16 03-04-2008 03:02 PM
Is a sti transmission swap possible in a 2006 wrx? 06wrxlbart Transmission (AT/MT) & Driveline 2 09-27-2007 10:58 PM
04 Wagon Sti Transmission Swap javastiwagon24 Transmission (AT/MT) & Driveline 2 03-25-2007 06:46 PM
