Old 12-20-2008, 06:59 PM   #1
michaelSVX
Member#: 180342
Default oil leaking 2.2
I have oil leaking from the rear of my passenger head. There is a round plug with 2 ears coming off of it, i'm sure that is the source. Can someone tell me what it's for so i can get a part# to fix it. All other gaskets and seals have been changed btw.
michaelSVX is offline   Reply With Quote
Old 12-20-2008, 08:51 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
ears? have any pictures?
Old 12-20-2008, 09:36 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
It's a cover plate for a distributor that we never got here in the states. IIRC, there's an O ring behind it. I would remove the plate, clean away the oil, and goop it up with Ultra Grey silicone.
Jay
Old 12-20-2008, 09:39 PM   #4
novacivic
Member#: 117980
2005 sti
wr blue
Jay
its actually reffered to as the right rear cam seal. call the dealer and buy a new o ring. all you have to do is remove the two bolts then twist the piece out, removed old seal, clean, replace o ring then reinstall. no sealant needed. should take about ten minutes.
novacivic is offline   Reply With Quote
Old 12-20-2008, 10:37 PM   #5
michaelSVX
Member#: 180342
thats the info i needed, thanks. I couldn't find anything with a search.
Old 12-21-2008, 05:39 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
If you use the grey silicone idea, make sure to let the silicone cure for 24 hours before running the engine.
~Josh~
Old 12-25-2008, 06:33 PM   #7
michaelSVX
Member#: 180342
sorry for the crappy pic, part#806946030
Old 12-31-2008, 10:59 PM   #8
A3Infidel
Member#: 155266
A3Infidel is offline   Reply With Quote
Old 01-07-2009, 09:57 AM   #9
Duke W
Member#: 199041
2002 Impreza 2.5TS
Whatever Green
I just picked up a '98 Impreza L wagon and it looks to have this exact same leak. Fortunately it doesn't seem too difficult to reach.
It appears to have a smaller leak at the front side of the left head. Any guesses? Cam seal there? That looks substantially less accessible.
Luckily, according to the service records, it's had the valve cover gaskets, oil pump gasket, and inner axle seals replaced about 30k ago.
Duke W is offline   Reply With Quote
2.2 rear cam plate oil leak 95subaru Normally Aspirated Powertrain 1 08-17-2006 01:25 PM
Small oil leak with 2.2 liter Legacy...Help anyone 98LegacyAWD Subaru Conversions 8 09-10-2004 12:48 PM
Oil leak on 2.2 liter engine 98LegacyAWD Service & Maintenance 4 09-07-2004 01:12 PM
2.2 Oil Leak found! Maybe... motoracr22 Normally Aspirated Powertrain 15 08-03-2004 02:41 AM
2.2 oil leak problem Kitsune Normally Aspirated Powertrain 1 03-12-2004 05:14 PM
