Old 12-21-2008, 04:42 AM   #1
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
Default Ticking noise under acceleration
I haven't paid much attention of this, maybe it's an existing problem, but I've been noticing this issue. When I slowly accelerate the car when the engine is moderately cold (before the water temp reaches normal operating range), the car would have this soft ticking noise. It goes away when I let go off the accelerator pedal. It is more pronounced when it reaches 2000rpm. When the car is operating in the normal range, the noise disappears. This happens more often during colder temperatures. Is there something to worry about? Or is it just one of the many things that being a Subaru owner have?
Spore is offline   Reply With Quote
Old 12-21-2008, 11:33 AM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
you may need to have your valve lash adjusted. do you notice it when in gear or in neutral?
Old 12-21-2008, 12:39 PM   #3
fornetti14
Member#: 103771
'00 Impreza 2.5RS
+1 on the valve lash. Not a bad job for a DIY'er.
fornetti14 is offline   Reply With Quote
Ticking noise from under Shifter Sandhawk Transmission (AT/MT) & Driveline 4 12-27-2009 01:32 PM
strange noise under acceleration r3xx Transmission (AT/MT) & Driveline 15 04-01-2008 03:52 PM
Engine noise under heavy acceleration - any thoughts? ccmah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-11-2006 06:01 PM
Feint Noise under load / acceleration rukkie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-23-2005 07:49 PM
Weird engine noise under acceleration Pakin Outback Forum 1 09-11-2003 09:59 AM
