Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 12-21-2008, 10:22 AM   #1
seanr2
Member#: 62697
2003 BAJA
Garnet Red
Question Here I Go Again... Trouble Starting!
This is the third winter I'll be writing about this, trouble starting my Baja. I woke up this morning to my baja being covered in a sheet of ice. I tried to start the car and it wouldn't turn over. On my 15th turn of the key it started up just fine. I've had this problem for 3 winters. I had a tune up one month ago (got new wires too), my battery was replaced 2 years ago with the onset of this problem, and I put a bottle of HEET in the gas tank yesterday. THE ONLY TIME THIS HAPPENS IS WHEN THERE IS ICE OR SNOW COVERING THE CAR. I can start this car at zero degrees with no problem as long as there is no ice or snow on the car. This problem dosen't happen with moisture in warmer weather just in case you might have been thinking that. THe dealer has never been able to help on this. After the car starts its good all day so mechanics never experience the issue when I take it in. ANY IDEAS?
seanr2 is offline   Reply With Quote
Old 12-21-2008, 02:36 PM   #2
bprich
Member#: 148972
2005 Baja-STI AT
Monterey/Brilliant Silver
Get a car cover.
bprich is offline   Reply With Quote
Old 12-21-2008, 05:11 PM   #3
DUDE ITS A BAJA
Member#: 197923
2006 BAJA SPORT
BLACK PEARL
one trick I've found with my friends 2005 turbo was if you opened and closed the hood hard enough to break off most of the ice it'll start up a bit easier.
DUDE ITS A BAJA is offline   Reply With Quote
Old 12-21-2008, 07:46 PM   #4
flstffxe
Member#: 155358
2008 Forester
Steel Silver
My vote is a bad connection/wire/cable some where, battery, battery cable, ground cable, ect.....
cold causes things to contract. A bad connection has high resistance which causes heat, which builds up after several attempts to start the car and thus causes that connection to expand and form a good connection allowing you to start the car. The ice on the hood may be just the icing on the cake that cools the car/connection off to the point of not working.
Start by checking all of the battery, alt., starter and ground connections. It may even be the starter, starter relay/solenoid it self. sadly this is some thing that can take a long time to chase down.
One thing to do would be do a wiggle test. When it wont start on the first try, start wiggling wires, cables and connection points one by one 'til you hit a jack pot. Wiggle one try and start, repeat.
flstffxe is offline   Reply With Quote
Old 12-24-2008, 10:51 AM   #5
BrunoShield
Member#: 155944
2003 Baja
Black Granite Pearl
I'm not sure this will help and I can't check because the Baja is buried in 9" of new snow, but I had a similar problem in a Dodge Dart. It turned out to be the bulkhead connector on the firewall. I'm going to assume the Baja has one? Normally they bolt or clip together but are not entirely weatherproof. I opened the one in the Dart, shot it full of contact cleaner from an electronics store, added some dielectric grease like they use on the spark plug boots, and closed it up. Never had a problem after that. That's about all I can offer.
BrunoShield is offline   Reply With Quote
here we go again...starting/running problems falnfenix Normally Aspirated Powertrain 4 05-07-2007 06:26 PM
OK, here we go again! Yellow Rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-07-2002 03:24 AM
here we go again! :) PR: Mongo Motorsports to sponsor SubieGal Racing Subie Gal North West Impreza Club Forum -- NWIC 11 02-28-2002 05:15 AM
Here we go again.... gtguy Mid West Subaru Owners Club Forum -- MWSOC 5 12-20-2000 10:28 AM
here we go again!!! Miller3339 North West Impreza Club Forum -- NWIC 23 02-24-2000 07:41 AM
