Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 12-21-2008, 02:01 PM   #1
Headstart101
Member#: 192664
2004 WRX STI
Default crying 04sti, please help!
Ok i took my car down a road last night, i was going about 60 when about 5 pot-holes came out of nowhere (couldnt slow down in time). Well i ended up ripping off my lip , then i got to my destination and was leaving about 15mins later, when i turn the wheel to the right i heard this crying sound coming from the right wheelwell and when i go straight it will go away.......i will put the car on a lift tuesday to see if i see anything out of place. anyone know what the problem might be? Tein coilovers is my only suspension mods
Headstart101 is offline   Reply With Quote
Old 12-21-2008, 02:39 PM   #2
Headstart101
Member#: 192664
2004 WRX STI
bump 4 help
Old 12-21-2008, 02:51 PM   #3
magnum2066
Member#: 158586
2009 WRX
Pearl White
http://videos.streetfire.net/video/T...when_68271.htm Like that? Busted axle. And don't be impatient with us, we have lives.
magnum2066 is offline   Reply With Quote
Old 12-21-2008, 03:16 PM   #4
Headstart101
Member#: 192664
2004 WRX STI
sounds almost the same but i dont think its a axle, car still drives normal in straight line......only when i turn right it makes that sound.........
More Hot Topics on NASIOC...
Old 12-21-2008, 03:41 PM   #5
k04sti
Member#: 171773
04 wrx sti
jbp blouch 2.5!
Lol a bump within 30 minutes.....
k04sti is offline   Reply With Quote
Old 12-22-2008, 03:36 AM   #6
STIBungy
Member#: 51684
2004 Impreza WRX STI
How about helping yourself and taking a peek under the car? Could be a million things causing that sound.
STIBungy is offline   Reply With Quote
Old 12-22-2008, 06:15 AM   #7
06WHTWRX
Member#: 173690
2006 wrx
CBR600F2
This has to do with powertrain how?
06WHTWRX is offline   Reply With Quote
Old 12-22-2008, 01:14 PM   #8
Emperor WuRM
Member#: 169737
2006 Wrx Tr
powersteering!!!!
Emperor WuRM is offline   Reply With Quote
Old 12-22-2008, 10:00 PM   #9
Headstart101
Member#: 192664
2004 WRX STI
its my clutch, i drove it around a little and it only makes the sound when im engaging the clutch. Once its get going it goes away untill i stop and try moving again, it shift good while moving but if i try to get it going from a stop it makes the noise. When im engaging the clutch it starts to cry but if i push the clutch back in it goes away. I dont want to drop 1700 for a new clutch and instalation right now so im going just baby it untill next year.
Old 12-22-2008, 10:50 PM   #10
magnum2066
Member#: 158586
2009 WRX
Pearl White
Possibly a throwout bearing.
Old 12-23-2008, 01:07 AM   #11
Headstart101
Member#: 192664
2004 WRX STI
^^^^^^^^^^how long can i drive like this?
Old 12-23-2008, 01:35 AM   #12
magnum2066
Member#: 158586
2009 WRX
Pearl White
We don't have physical access to your car so it is hard diagnose. It could simply be the throwout bearing, clutch, or both. Both are rather spendy because they require dis-assembly of the drivetrain just to get to it. Anyways you need to get under your car and take some quality pics in order for us to help. I do suggest bringing it to a knowledgeable mechanic/dealer and have them diagnose it anyways though to know for sure. They can also quote the work that needs to be done at the same time.
Old 12-23-2008, 01:41 AM   #13
hybrid gti 2
Member#: 67004
02 silver vf30 wag
05 f250 lifted on 35's
Jack it up and check that wheel bearing.
hybrid gti 2 is online now   Reply With Quote
Old 12-23-2008, 01:44 AM   #14
magnum2066
Member#: 158586
2009 WRX
Pearl White
I also second that, going by your first post Headstart. I had to jump a curb once and the wheel started squealing when its cold out on my car. Simply a damaged wheel bearing... Which only costs about $25-30 in parts but is a ***** to install.
Old 12-23-2008, 09:41 PM   #15
Headstart101
Member#: 192664
2004 WRX STI
sorry im a noob, i have no idea where the wheel bearing is but ill take pics of the car tomorrow and post them
Old 12-23-2008, 10:03 PM   #16
magnum2066
Member#: 158586
2009 WRX
Pearl White
You can't really see it. You test the wheel bearing by jacking the tire off the ground and jerking on it. If it has lots of play it need to be replaced. Other than that we just want pics from under the car just to see if anything important got hit. Take lots of pics of the bottom of the engine and transmission.
Old 12-24-2008, 12:07 AM   #17
Headstart101
Member#: 192664
2004 WRX STI
I was driving home tonight and felt like the clutch was slipping in 6th....rpms reved up but car felt like it didnt increase speed
Old 12-24-2008, 12:16 AM   #18
magnum2066
Member#: 158586
2009 WRX
Pearl White
Please update your profile so we know what car you have. Again I suggest paying the $20-50 to have someone else diagnose it. If it is doing that something is obviously wrong with the car. Anyone know if a clutch can be bumped out of alignment and if it could be a factor?
Another blind guess would be a broken axle or two... If the clutch was slipping you would somewhat be able to feel it in the pedal because when you lift your foot off the gas you would feel it grab again. If it isn't the clutch then it is the center differential being worked to death. In that case GET IT FIXED or it becomes more and more expensive from there.
Old 12-24-2008, 12:52 AM   #19
Headstart101
Member#: 192664
2004 WRX STI
If it's the clutch i will just wait till next year and put a 6 puck in, i dont think the axles are broken, the noise is only coming from one spot and it dont happen all the time but happen too much not to notice, and it only happens while im engaging the clutch. i will take it to the dealer tomorrow and see what they say...and when the clutch seem like it was slipping i was using cruise control but i can just be stressing from the problem. Thanks for all the advice i will post picks and result from dealer
Old 12-24-2008, 02:22 AM   #20
whitewagon8619
Member#: 174852
2005 wrx wagon
hybrid swap 68hta
going to the dealership is def your best bet.
whitewagon8619 is offline   Reply With Quote
Old 12-24-2008, 07:40 PM   #21
Headstart101
Member#: 192664
2004 WRX STI
well subaru dealership is closed till friday, and its a $100 for them to tell me whats wrong.
is that the normal price
Old 12-24-2008, 08:34 PM   #22
magnum2066
Member#: 158586
2009 WRX
Pearl White
Is that a flat fee or per hour diagnosing?
Old 12-24-2008, 11:26 PM   #23
Headstart101
Member#: 192664
2004 WRX STI
i believe its a flat fee, i think thats way too much. they should be able to tell whats wrong within 10mins of driving the damn thing
Old 12-25-2008, 02:07 AM   #24
magnum2066
Member#: 158586
2009 WRX
Pearl White
:/ That is far too much in my opinion. Any other dealers nearby that will charge by the hour?
Old 12-25-2008, 04:28 AM   #25
Headstart101
Member#: 192664
2004 WRX STI
well i got the price from a saturn dealer next to subaru dealer, subaru was doing their servicing at saturn so i think they would know what subaru charge
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 12:57 PM.
