Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 12-21-2008, 03:27 PM   #1
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Question 97 Legacy L dual port or single port?
as the topic said the exhaust port is it dual or single?
SubaruImpreza_power is offline   Reply With Quote
Old 12-21-2008, 04:36 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Should be single port. Dual ports only came on the 1990-1995 models, of legacy at least, not sure the cutoff point for the imprezas. You could always poke your head under the engine to take a look. If here are 3 bolts holding the exh. manifold on, its dual port. If there are only 2 bolts, it's single port.
~Josh~
Dual or single port heads Black_Rain Normally Aspirated Powertrain 4 09-18-2006 01:48 PM
EJ22 SOHC Dual Port or Single? Mechkiller31st Normally Aspirated Powertrain 6 03-18-2006 08:38 AM
99impreza L 2.2 dual or single port ? 99subi Normally Aspirated Powertrain 2 03-06-2005 05:45 PM
Dual port head or Single port head ? G.Subramaniam Normally Aspirated Powertrain 5 06-25-2004 12:09 PM
('93-'01) dual tip or single? Ragstylz Impreza Forum 37 10-23-2001 04:45 PM
