#1 |
Member#: 171272
Vehicle:2004 wrx wagon san remo red |
hi,
is Valvoline synthetic blend 10w-30 the same thing as normal synthetic?
#2 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
no
Ive been using the 10w40 Maxlife for a while.......good stuff I think |
#4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
Synthetic blend is a waste. Either use full synthetic or conventional organic oil.
#5 |
Member#: 141672
Vehicle:07' wrx Uncle Scotty 5W30 |
Most will not believe this, but the requirement to meet today's specs for some weights without ubber expensive additives means they are already partially synthetic oils to begin with. Engine oil companies don't tell people this so they can sell synthetic blends and make more money. An exception comes from Kendall and Conoco oils (5W20, 5W30 and 10W30) that clearly states they are a synthetic blend. Those two oils often cost less then so called dino oils from bigger oil companies who do much, much more advertising & sponsoring.
I would love for bluesubie to chime in and correct me if I'm wrong? |
#6 |
Member#: 16200
well...that Valvoline MaxLife is ~$2.60/qt when bought in the 5qt jug at walmart and is acea A3
#7 |
Member#: 118209
Vehicle:2002 WRX Sedan |
Synthetic blend could be .05% synthetic, and 99.95% conventional oil. There are no requirements at all about synthetic blend, stay away, it is just a money trap.
#8 | |
Member#: 767
Vehicle:04 FXT |
Go with Max Life (full synthetic or blend) or Synpower. Use Synpower just because of their new cool ads bashing Mobil1. ![]() -Dennis |
| Thread Tools | |
| Display Modes | |
| I know IT will blend, but SHOULD I blend? | sonicblue | Off-Topic | 12 | 05-03-2007 01:06 PM |
| Switch to Syntheic, when and how??? 06 WRX | WRXWagonFun | Service & Maintenance | 27 | 12-24-2005 12:43 PM |
| Motul 300V Racing Syntheic | So Cal STI | Service & Maintenance | 10 | 08-23-2005 12:24 AM |
| Paint, to blend or not to blend? | aarchewrx | Interior & Exterior Modification | 9 | 03-11-2005 10:02 PM |
