Old 12-21-2008, 10:40 PM   #1
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Default Bosch Fuel Pump Users?
Anyone here using a Bosch 044 pump with stock ecu? or without a controller?
I'm interested in seeing how long these pumps will work if they are run at 100% duty cycle for extended periods of time.
Token-Negro is offline   Reply With Quote
Old 12-22-2008, 07:53 PM   #2
modaddict
Member#: 95840
sold to a good bud
awaiting next car
This pumps are for big power. I wonder how many people run them?
interested..........
modaddict is offline   Reply With Quote
Old 12-22-2008, 11:07 PM   #3
CatfaceType-R
Member#: 81102
you might want to try posting this in the built motor discussion part of the forum. Most people here are just running a double pumper I see more people run the bosch with built motor setups for some reason or in that part of the forum
CatfaceType-R is offline   Reply With Quote
Old 12-22-2008, 11:51 PM   #4
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
My post got moved, it started in motorsports since this is generally a motorsports used pump, figured someone might have one on there race car. Well Off to BMD see whats up in there.
Old 12-23-2008, 12:29 AM   #5
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
The Bosch 044 fuel pump is widely used in motorsport applications and is known to be very reliable.
I run a Bosch 044 external pump (mounted off a surge tank) on my WRX and it's been great so far. I've ran this setup for a year in my mostly daily driven car and it's still going strong. The pump is powered directly from my battery through a relay and I'm using the stock fuel pump controller to control it (Hydra EMS).
-Dan
suby_dude is offline   Reply With Quote
Old 12-23-2008, 03:08 AM   #6
kmurphy
Member#: 163257
2006 sti
obp
shouldnt this be in the newbie section
kmurphy is offline   Reply With Quote
Old 12-23-2008, 08:33 AM   #7
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
if you run the pump on the oem wiring there is a good chance that the oem wiring will not be able to handle all the draw, causing your car to run lean under full boost
it is not too bad to set up the pump, i did the wiring and install on my intank pump set up
pm me if you want
blowbyu24 is offline   Reply With Quote
Old 12-23-2008, 12:13 PM   #8
suby_dude
Member#: 17397
WRB, White
Yea it's best to power a pump of this size off of your battery through a relay. I just use the stock pump controller to trigger the pump on and off easily, all power comes from the battery though
-Dan
Old 12-23-2008, 11:18 PM   #9
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
-Dan
Thanks Dan so that means 100% duty cycle all the time one year worth and still going strong. How is the noise from it? Care to post a picture?
Old 12-24-2008, 04:30 PM   #10
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
Noise isn't bad at all if you have the back seats in. I drove around without back seats until the noise of the pump in combination with the exhaust drone and road noise drove me nuts.
-Vic
ec2k1gt is offline   Reply With Quote
Old 12-24-2008, 07:21 PM   #11
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
^^^^haha too funny, i didn't put the seats in until i got a headache from riding in my car
the bosch is not nearly as loud as two walbro pumps
Old 12-24-2008, 07:35 PM   #12
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I disagree! External pumps are DEFINATELY louder.
This is Dans setup.
smp surge tank + bosch044
You could also do the txs surge tank setup like so...
I haven't decided on which setup I want to do, however I need to decide fast because it's the last thing on my list.
D Money is offline   Reply With Quote
Old 12-25-2008, 08:58 AM   #13
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
my bosch is intank, so external i am sure its louder....but two intank walbros were louder than my bosch thats in there now
Old 12-25-2008, 06:53 PM   #14
spiralsmurf
Member#: 16085
2005 STi
how did you install the 044 intank?
spiralsmurf is offline   Reply With Quote
Old 12-26-2008, 01:49 PM   #15
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
same way you would install a 255 walbro execpt for the wiring
Old 12-26-2008, 09:37 PM   #16
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
So this would actually be the 040 bosh right?? The in tank version? Not the 044 which is the inline. Just want to clarify.
nosmo is offline   Reply With Quote
Old 12-27-2008, 02:37 AM   #17
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
There is only one 044 some seem to mount them in tank, but the 040 is the intank version by design.
Old 12-27-2008, 07:34 AM   #18
ovr_bst
Member#: 111298
2006 WRX TR stg 2
Crystal Grey
I have run the 044 outside of tank and even worse in the front of vehicle [pulling fuel] for two years straight on my dd dodge daytona no probs
ovr_bst is offline   Reply With Quote
Bosch Motorsports 44 fuel pump THE-95-STi Built Motor Discussion 27 05-24-2010 09:27 AM
FS: new Bosch 044 fuel pump garagedefeat Engine/Power/Exhaust 7 04-08-2008 10:18 PM
bosch 040, and 044 fuel pumps Sinister redlines Built Motor Discussion 2 03-14-2008 11:21 PM
Bosch Motorsports 044 Fuel Pumps Jay Racing Private 'For Sale' Classifieds 2 11-16-2005 09:46 AM
Bosch Fuel pumps... DeliciouSpeed Normally Aspirated Powertrain 25 02-21-2001 12:15 AM
