Old 12-22-2008, 12:32 AM   #1
SpankySuby
Member#: 122305
2002 wrx half breed
Default Battery Relocation Kit
Just a quick question guys for Auto-x and Track racing is it legal to have a battery relocation kit done and does it matter where i put the battery(in the trunk).
SpankySuby is offline   Reply With Quote
Old 12-22-2008, 12:54 AM   #2
fengrr
Member#: 169160
03 WRX
Black on WRB
I think it effects your class.
And it also might have to be secured a certain way. Or in a box or something.
fengrr is offline   Reply With Quote
Old 12-22-2008, 01:00 AM   #3
impreza_GC8
Member#: 123295
2000 2.5RS moneypit
2012 Ford Fusion 6MT (DD)
Your class (STX at minimum) allows it to be in the trunk secured properly. You don't need an external shutoff however if you try to drag race your car with a rear battery and no shutoff I think you will fail tech.
impreza_GC8 is offline   Reply With Quote
Old 12-22-2008, 07:11 AM   #4
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Read the rule books for the venues you're interested in participating in. No answer here is going to be 100% correct.
Old 12-22-2008, 08:09 AM   #5
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Bingo.
Fitz is offline   Reply With Quote
Old 12-22-2008, 09:24 AM   #6
KC
Member#: 442
13 Crosstrek XV
00 S2000
Barring that, why does anyone relocate the battery with the much heavier cables (additional weight!) and not just get a smaller one like the tractor/Hawkeye batteries?
IMHO, ~7 lbs in the front is much better than 25+ lbs of cables and full size battery in the rear.
Lighter > additional weight (even tho trying to re-distrube it)
--kC
KC is offline   Reply With Quote
Old 12-22-2008, 09:56 AM   #7
dunk
Member#: 15359
--kC
Can't speak for the autox guys, however on a road course car sometimes the classes have minimum weights, in which case any excuse to move something from the front to the rear of the car is nice. If you have to add ballast anyways, you may as well try and get some weight off the nose, even if it is only 7 lbs. Plus, if you have tubbed front fender wells you quickly run out of the room for the battery.
Duncan
dunk is offline   Reply With Quote
Old 12-22-2008, 11:29 AM   #8
XmanSTi
Member#: 65206
1986 Brat
Red
Rally cars also want a nice big battery as extra source of power when running the big driving lights at night. I've seem teams go so far as run two batteries. Their thinking is it's better to finish than to DNF for battery failure which is kinda common when you start banging around on stage.
XmanSTi is offline   Reply With Quote
Old 12-22-2008, 11:55 AM   #9
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
Yeah those tiny batteries die with the quickness.
Plus, overall weight loss is not always better than weight re-distribution. The Optima Red-top, which is an awesome, dependable battery weighs a ton. I'd rather have a couple extra pounds in cables, and move it to the trunk, then have about 40 pounds sitting at the extreme front left of my vehicle.
slowscooby is offline   Reply With Quote
Old 12-22-2008, 12:21 PM   #10
BIGSKYWRX
Member#: 7958
09 GH B+
interesting question ~ 25 lbs off the front end or add and relocate ~ 60 lbs (you need bigger than oe wires if running from the trunk and something to secure it w/)
clearly easier and cheaper w/ option #1, I can see option #2 being viable if your at min. weight and just want to move it somewhere else
Old 12-22-2008, 01:03 PM   #11
KC
Member#: 442
13 Crosstrek XV
00 S2000
I have one in my Civic, have had it for a year, it's 10 degrees outside and it's still alive and healthy in my daily driver.
--kC
Old 12-22-2008, 02:04 PM   #12
zoomfactor
Member#: 30440
03 WRX
WR Blue
I ran one of the small Optimas in my car for 3+ years without problems. With the terminal (bolt) adaptors it was less than $70 and less than 15# (weighed on a digital scale).
zoomfactor is offline   Reply With Quote
Old 12-22-2008, 02:08 PM   #13
KC
Member#: 442
13 Crosstrek XV
00 S2000
Just don't leave the lights on if the engine isn't running. I've done that twice coming in to work where it's dark and then light out and no 'your lights are on' chime.
--kC
Old 12-22-2008, 02:15 PM   #14
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
Again....it'll depend on class.... My CRX is in prepared, so I can do pretty much anything I damn well please.... I have an SCCA legal batt cutoff on the front pass part of the cage. The same cable that went into the stock underhood location reaches behind the pass seat on the floor. So that's where it is now. Lower, right side, farther back. And zero cost. win, win, win, and win.
jack
Battery Relocation Kit for Subbies ?? soobyfan Electrical & Lighting 8 05-30-2005 01:18 PM
looking for good battery relocation kit petawabit Electrical & Lighting 1 04-03-2005 05:42 PM
best battery relocating kit??? damn_4eat Electrical & Lighting 8 04-28-2004 09:42 AM
Battery Relocation Kits BongMan Normally Aspirated Powertrain 25 09-16-2001 01:29 AM
For sale: battery relocation kit bill harvey New England Impreza Club Forum -- NESIC 3 03-04-2001 03:39 PM
