Notices
Old 05-20-2014, 12:12 PM   #1
Obababoy
Member#: 158888
2011 STi EFR 7163!
07 GT30 WRX sold :/
Default VIDEO: 2011 sti, EFR 7163, hesitation, unsure of source
Mods:
Full-Race EFR 7163 v-band up/dp, 'stock' location, iwg, built in bpv.
ID1000's
DW300 FP
Tomei Type L FPR with 2 06sti dampers. FPR not adjusted to 43.5 psi yet
MAW Composite TGV's
Invidia Q300 CBE
Crawford v2 AOS
KStech CAI v2 73mm big maf
The car is running fine under no load but as soon as I get to around 2psi I get this stutter https://www.youtube.com/watch?v=drMspy4jD14 , https://www.youtube.com/watch?v=B_cX5apeFCg.
My tune is Friday so I am trying to track down the issue. A couple things to note. This is the base tune they sent me. Neither the wastegate nor fuel pressure have been adjusted yet, so it could be an issue with either of them. If anyone could rule out FPR pressure, IWG, or boost leak id be grateful for any one of those so I could focus my efforts.
Chris
Obababoy is offline   Reply With Quote
Old 05-20-2014, 12:20 PM   #2
STiZzle2010
Member#: 250144
2010 WRX STi
Dark Gray Metallic
I had a similar hesitation between 2500-3200 RPM and from what I have read, it is pretty common on the GR's. I got the fuel pressure regulator kit from Cobb and a tune which resolved my problem 100%. Not sure if this is what you are experiencing but hope it helps.
http://www.cobbtuning.com/Subaru-08-...t-p/315100.htm
STiZzle2010 is offline   Reply With Quote
Old 05-20-2014, 01:02 PM   #3
Obababoy
Member#: 158888
2011 STi EFR 7163!
07 GT30 WRX sold :/
Thanks but im fairly certain this isnt the case because if I slowly rev past 3200 then give it more gas it does it at any RPM's. I also have an aftermarket FPR and new 06sti dampers(although I dont think the compensation tables have been cleared).
Old 05-20-2014, 01:21 PM   #4
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
Make sure the vac source to the BPV is correct, other than that put some smoke and then some pressure into her and see if anything is failing under load (clamps, hoses, caps etc.).
If it's solely load related and mechanically everything checks out fine then have your tuner look at it (I assume it's been tuned with such mods before and your going to just clean/heighten the tune?).
Also, do NOT entrust that you will get a resolution or diagnosis without getting your hands into the car, what you know is MORE than what we know because there are other factors that could be at play. Don't forget, this board has been filled with people who've taken cars, modded them to hell and haven't tuned them in and wonder why X is happening when Y is done.
Get yourself and your car with someone who's willing to help you out track what's going on, there are procedures to these things...
-Mark
APM Tuned is offline   Reply With Quote
Old 05-20-2014, 01:32 PM   #5
Obababoy
Member#: 158888
2011 STi EFR 7163!
07 GT30 WRX sold :/
Thanks Mark,
I went from a TXS 50/50 on my stage 2 setup to the BPV located on the 7163, so I just hooked up the vacuum line from TXS unit to my BPV on turbo.
Car hasnt been tuned other than a base map from them. They are swamped so I can't get in there before my tune date(which they allotted a bit more time in case of issues).
I just feel like most boost issues make a squealing noise or just make the car run lean or not boost(could definitely be wrong). This issue is jolting and feels like a fuel cut. The first video you can notice the jolt.
