Old 12-22-2008, 10:02 AM   #1
Azar
Member#: 139349
1988 LS1 Swapped RX7
1996 RHD Ver2 WRX
Default Help! Upper rad. hose exploded on way to work
Okay, upper radiator hose exploded on the way to work today.
Question: What upper rad. hose will work on EJ20G in 96 Scoob? Should I gun for the OE 2.2 equipment or the Bugeye 2.0 hose? Thanks.
Sorry if this has been answered before, I'm at work so I had to make it real quick.
Azar is offline   Reply With Quote
Old 12-22-2008, 04:09 PM   #2
Aphex28
Member#: 11506
2015 WRX
matters on which radiator you have.
The radiator either has it's port on the passenger side of it, or in the center section. If it's on the side, use your stock one, if it's in the middle. Use a wrx one.
Aphex28 is offline   Reply With Quote
Upper Rad Hose Hot, Bottom Cold? HELP LostCause Built Motor Discussion 7 01-11-2010 12:28 PM
Pics of 2 jacked up Hondas I saw on way to work MyOtherRideIsUrMom Off-Topic 35 02-03-2009 02:58 PM
SAW THIS ON WAY TO WORK (evo content) RtomS Member's Car Gallery 33 03-04-2005 08:33 PM
id on upper rad hose for WRX? cantex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-04-2001 11:24 AM
I.D. on upper rad hose for WRX? cantex Texas Impreza Club Forum -- TXIC 0 12-04-2001 10:28 AM
