Old 12-22-2008, 11:15 AM   #1
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Default OEM or stage 1 clutch?
I just bought Delta cams 1000 grind and wanted to get a LW flywheel and clutch to install while the engine was out. I was planning on going with the OEM exedy clutch but can't find any numbers on hp or torque ratings. I wouldn't imagine my car is pushing the limits of the clutch but would a stage 1 be a better idea? I have OBX ELH, Cobb CAI and CBE, PP6 EM and Perrin crank pulley. Does anyone know what the hp numbers for an OEM clutch and exedy OEM or stage 1 are?
aclver1 is offline   Reply With Quote
Old 12-22-2008, 11:50 AM   #2
ArcticWolf
Member#: 146732
2006 Impreza 2.5i
Obsidian Black Swirl
The OEM clutch can handle much more than our engines can put out, and is nicer to your transmission.
Wrong forum, btw.
ArcticWolf is online now   Reply With Quote
Old 12-22-2008, 11:52 AM   #3
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
yeah I know but I wanted to hear from NA guys and not people 250+ hp. Thanks
Old 12-22-2008, 05:11 PM   #4
jordan s
Member#: 122233
1997 Legacy GT
Aspen White 5MT
stick with the OEM. and when you install the lightened flywheel, remove the lightweight crank pulley.
jordan s is offline   Reply With Quote
Old 12-23-2008, 03:49 PM   #5
VIsubi
Member#: 187834
06 2.5i impreza
Red
you choose either way makes no difference..stage one is about 20% to 30% more holding power really if you can get the same price for both go with the stage 1 either way makes no difference but once you go bolt on turbo or swap..stage one will last a bit longer.....thats if you plan on going that route. If not the stage 1 will just last longer.
VIsubi is offline   Reply With Quote
Old 12-23-2008, 08:14 PM   #6
jordan s
Member#: 122233
1997 Legacy GT
Aspen White 5MT
the OEM organic material clutch can heal itself when it overheats, the stage 1 can't.
Old 03-03-2009, 09:54 PM   #7
kh15
Member#: 132400
what do you have to do to cause a clutch to overheat? i would think you would either A: really suck at driving, or B: doing something you shouldn't be doing to your car anyway like dropping the clutch.
kh15 is offline   Reply With Quote
Old 03-03-2009, 09:59 PM   #8
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Stop and go driving can overheat the stock clutch pretty easily, especially on an incline.
chazly413 is offline   Reply With Quote
Old 03-03-2009, 10:00 PM   #9
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
The usual question: what do you use the car for?
I personally need to switch to a better clutch, since while racing it does slip a little (after a shift, usually), and once it heats up it gets a bit stinky. Switching to a non-organic compound on the clutch would fix that right up for me.
However, if it's just about holding the power i woudn't worry about it, since you won't be heating it up much on a regular basis.
sniper1rfa is offline   Reply With Quote
Old 03-03-2009, 10:37 PM   #10
kh15
Member#: 132400
simple everyday driving and some spirited driving every now and then. i never race or go crazy.
even though my on a stage1 exedy clutch now i really dont see how normal driving even if your not absolutely 100% perfect at it can cause a clutch to overheat. If that was the case 80% of manual transmission car owners would be getting there clutch replaced every 20k
Old 03-03-2009, 11:13 PM   #11
GreenEJ
Member#: 198994
2002 Outback Sport
Savannah Green Metallic
reason for this?????
GreenEJ is offline   Reply With Quote
Old 03-03-2009, 11:55 PM   #12
jordan s
Member#: 122233
1997 Legacy GT
Aspen White 5MT
having both can cause misfires.
Old 03-04-2009, 05:46 PM   #13
bsikora
Member#: 125573
2006 2.5i
ProTune by Sean S.
yep! i was going to say throw codes but thats what it is....
bsikora is offline   Reply With Quote
Old 03-04-2009, 05:54 PM   #14
rougeben83
Member#: 115154
2005 Outback XT
White on grey
actually you're right. The revs drop way faster and the ECU thinks the car misfires and throws the code.
rougeben83 is offline   Reply With Quote
Old 03-04-2009, 10:18 PM   #15
VIsubi
Member#: 187834
06 2.5i impreza
Red
stage 1 don't worry bout it healing itself...cause if your insstalling cams or getting someone to then you probably know what your doing...plus i doubt it'll do much to your tranny other than holding power...
Old 03-04-2009, 11:06 PM   #16
kh15
Member#: 132400
installing cams....?
BNIB exedy stage 1 clutch 15804 $335 picked up Wannascooby SCIC Private Classifieds 19 07-15-2010 04:18 PM
Greetings from down under! Exedy clutch for 04 STi - OEM or stage 1 sports org.?? mr_tt Transmission (AT/MT) & Driveline 3 10-25-2009 02:16 PM
Where to get stage 1 or stage 2 clutch it VIsubi Transmission (AT/MT) & Driveline 4 05-28-2009 10:27 AM
WTB 06-07 WRX stage 1 clutch, oem 06-07 flywheel JDMFLCL Private 'Wanted' Classifieds 0 12-26-2008 09:40 PM
02 WRX Exedy Stage 1 clutch kit or OEM eddie1982 Private 'Wanted' Classifieds 13 05-14-2006 11:59 PM
