Old 12-22-2008, 02:03 PM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Default P0134 CEL - again?! Need advice on what went wrong
I had this CEL pop up on me back in summer after 88k kms on the car, so I figured front O2 was shot - I changed it, everything went back to normal for 2 months that I drove the car
now the car has been sitting in my garage for 4 months, and I finally took it out this past weekend, made some adjustments for winter and calibrated OL MAF
now, as I was driving back home today, put the car under load (6th gear) the CEL pops out again! I come back home, read it - P0134, front O2 not responding!
Can the sensor die after 2 months of usage? It was new when I bought it, moreover it had to come from japan since my car is twinscroll and it goes in the DP
So because it costs arm and a leg, I don't feel like changing them every other month
My EGTs are adequate (max 780c, EGT probe in DP) so it couldn't have burned, right?
erasing CEL doesn't help, comes back on, and I know I can't disable it since ECU makes adjustments to CL relying on it
Hyper is online now   Reply With Quote
Old 12-25-2008, 02:58 PM   #2
ccsrcr
Member#: 197647
2004 STI
Not sure what setup you have, but I had the same problem, and it ended up being a lose connection at the ECU (the UTEC in my case). I was able to watch the dashboard on the UTEC and wiggle the connection and I could see the O2 readings fluctuate.
ccsrcr is offline   Reply With Quote
Old 12-25-2008, 03:20 PM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
hm, didn't think about that
I know O2 goes directly to ECU, so I will check there, thanks
what's weird is that CEL dissappeared again, so I don't know when it will pop up again
Old 12-25-2008, 09:26 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
wiring....plug...ground issue???
Need advice on what finish Torques for my white STI AlxSti Tire & Wheel 36 09-26-2009 05:11 PM
Need advice on what parts to get. ndubz Newbies & FAQs 18 11-21-2008 12:58 PM
hello , need advice on what next ,bored of the 20G vulpina Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 04-10-2008 09:28 PM
OT Officers Of the Law: Need advice on what to do next. sc00by4life Off-Topic 47 10-15-2006 02:43 AM
need advice on what to do next t3ch9 Engine Management & Tuning 1 06-24-2005 04:18 PM
