Old 06-06-2011, 04:31 PM   #76
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
As long as the holes are filled and/or welded shut, that's correct, just pull it all out.
Old 06-06-2011, 04:32 PM   #77
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Daily driver status son
thanks for the quick responses!!
Uncle Tattoo is offline   Reply With Quote
Old 06-09-2011, 09:16 PM   #78
lowwill
Member#: 263598
Wow now Im really confused. Heres my issue. My cel light came up (p2016) when I cracked the sensor getting at the banjo bolt in April. My only car so I silicone it and it seem to run fine no idle issues or things of that nature. Erased it with my reader. Today it comes back on. Again no notiable idle/roughness. I dont need any deletes. How difficult is it to change out the sensor itself. I dont see any write up about it. Does it make any difference if driving it with the cel on or off? Seen something about pulling the sensors and just getting it ''tuned''? Im new so feel free to flame. Excellent site though. Keep up the good work people. 05 OBXT 93k stock..
lowwill is offline   Reply With Quote
Old 07-24-2011, 04:28 PM   #79
skep18
Member#: 214971
2014 WRX
I'm in the exact same boat. I installed an UP and must have done something wrong as I have P2016 reading now (no other codes). However, contrary to the Sticky, my tuner says the TGV motor runs independently from the sensor, i.e. it runs on a open loop. This means the sensor acts ONLY as a warning flag to identify a failed TGV motor. Inversely, the bad sensor DOES NOT have any affect of the functionality of the actual TGV motor.
To support this, I've had the code for a week, thinking it was the typical missing UP EGT sensor code, and the car has run fine during all driving conditions, i.e. no limp mode. However, the tuner does seem to suspect that this open loop function may not exist on certain newer 2007+ Subaru models, hence the winding spring installation. In newer Subarus, there's no winding to install sort of feature.
Let me end this by, no, I'm no expert. Unibomber may very well come in and correct me, but with this code, my car still runs fine. I will be fixing it soon.
(2005 WRX, stage 2, TBE and UP)
skep18 is offline   Reply With Quote
Old 07-24-2011, 05:20 PM   #80
WrxWrb
Member#: 287477
02 Wrx Wagon WRB
EVO III 16g=Fun
You got the code meaning something is more then likely broken or failing. I had the code a while back after doing an inlet install. Code went away and never came back but the car never really seemed to be running right.
Finally got around to doing the deletes and the car immediately started better and just felt better. I am now getting a tune for them.
WrxWrb is offline   Reply With Quote
Old 07-28-2011, 11:02 PM   #81
Rexwagon1909
Member#: 285276
Na WRX
Na
Will 2.0 top feed deletes work on a 2006 top feed WRX?
Rexwagon1909 is offline   Reply With Quote
Old 08-16-2011, 12:15 AM   #82
AWDkidRS
Member#: 254133
2001 RS *EJ205*
^^Yes as long as they are both TF.
The grimmspeed diy is not working?
AWDkidRS is offline   Reply With Quote
Old 10-15-2011, 10:27 PM   #83
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Should be same.
I am doing this now and was initially gonna leave rod and motor/sensors in. But then I realized I would be pissed if I got em all back together and code was still throw due to me lousing up the reinstall. Filling holes seem more logical.
Gonna plug em with special whale sperm and toenail clippings and call it a day.
Or tap and fill em with bolt and some JB.
sackytar is online now   Reply With Quote
Old 01-23-2012, 11:10 PM   #84
ROIDSgotBOOST
Member#: 275071
06 STi
World Rally Blue
Well written. In Favorites.
ROIDSgotBOOST is offline   Reply With Quote
Old 01-24-2012, 09:12 PM   #85
mtnman711
Member#: 273494
2004 WRX Wagon
Java Black Pearl
Crap. I wish I'd read this when I had my manifold in pieces... I would have definitely put in the work at that point. Nice write-up, Ron.
mtnman711 is offline   Reply With Quote
Old 01-24-2012, 09:54 PM   #86
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
speaking from experience, dont use JB weld.
i got a set from a friend who got them from someone else on here, and i ran on my car for 6+ months til i pulled them to install my new manifold. the jb weld was literally loose and spinning in the rod holes.
i tapped and installed allen head bolts. i did have to use 2 different lengths, but i havent had a problem since.
Old 02-07-2012, 12:46 PM   #87
SubaDre7
Member#: 242645
Bump! Those are some extraordinary directions and advice! Thank you so much!
SubaDre7 is offline   Reply With Quote
Old 02-21-2012, 09:51 PM   #88
chadb
Member#: 198179
2007 STI
UGM
Good info...
chadb is offline   Reply With Quote
Old 03-31-2012, 01:30 PM   #89
chadb
Member#: 198179
2007 STI
UGM
Sweet write up..
Old 03-31-2012, 08:13 PM   #90
4drs4morewhorrrz
Member#: 315295
Awesome info much appreciated
4drs4morewhorrrz is offline   Reply With Quote
Old 04-29-2012, 01:44 PM   #91
RIPNBST
Member#: 314403
2007 STi
Great Write Up, this sounds like it would be pretty straight forward. I have a 2006 STi, anyone know what JDM spacers I would need so that they are compatible?
My car will be able to be down for two weeks so I'd like to do this while I can.
RIPNBST is offline   Reply With Quote
Old 05-09-2012, 12:39 PM   #92
prettyinpink
Member#: 260109
2005 Impreza WRX STi
aspen white
i am thinking about having my TGV delete dont through the grimmspeed service. does anyone know if they address filling in the holes? Great write up btw. EXTREMELY informative
prettyinpink is offline   Reply With Quote
Old 06-18-2012, 10:42 AM   #93
redmatter
Member#: 323470
Will removing my tgv's cause me to fail Colorado emissions and will me not deleting them effect my huge turbo besides the less power??
redmatter is offline   Reply With Quote
Old 06-18-2012, 11:13 AM   #94
Member#: 51961
2005 STi
2012 WRX
No, and no
Old 06-18-2012, 11:28 AM   #95
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
removing TGV's will cause you to fail SAFETY (most states) but not emissions. You'll fail SAFETY DUE TO CHECK ENGINE LIGHT unless if you turn it off with AP or Tactrix.
- An NO it will not effect your HUGE turbo ... removing them an porting an polishing your intake manifold/tgv housings will give you some improvement however.
white guys wrx is offline   Reply With Quote
Old 06-18-2012, 11:48 AM   #96
Member#: 51961
2005 STi
2012 WRX
You have to remove the CEL otherwise the car will be thrown into limp mode, so that's a given.
Old 07-07-2012, 01:00 PM   #97
leemwalls
Member#: 325396
2014 WRX Hatch
WR Blue
Talking
My hands are bleeding from grinding.... God help me...
Mission Accomplished though..
leemwalls is offline   Reply With Quote
Old 07-07-2012, 01:05 PM   #98
paulpat
Member#: 237145
02 WRX
12 FXT
thats a good feeling right?
Now start porting and polishing!
paulpat is offline   Reply With Quote
Old 09-23-2012, 12:27 AM   #99
jhayesvw
Member#: 326502
2003 WRX Wagon
so if I have a protune on my car can I do the TGV deletes and have the tuner disable the motors and therefore CELs with my Cobb AP?
jhayesvw is offline   Reply With Quote
Old 10-20-2012, 11:29 AM   #100
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Tap & Bolt Method
V8 GTFO Lesbic WGN is offline   Reply With Quote
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 296 02-15-2016 03:16 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 317 09-03-2015 08:56 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 110 07-02-2015 11:25 PM
