Old 12-22-2008, 07:48 PM   #1
njwrx10
Member#: 169265
2011 STI
Default 255/40/17 or 245/40/17?
Hey i cant decide between the two. I like the look of the 255/40/17 better but i am not sure if they will rub on the inside or outside fender.
I currently have Rota Torques 17x8 and i have lowerd it with Tein H-techs and KYB-Agx struts.
Can someone help me out here, from experience.
njwrx10 is offline   Reply With Quote
Old 12-22-2008, 09:46 PM   #2
wopdeeze
Member#: 148597
00 GDA Jet Black
04 GGA PSM 10 SH5 XT
what offset are your rims? also, you will probably be limited to 235 45 17 considering what suspension you are currently running. i am currently working on running 255 40 17s on my car and im running dms 40 mm coil overs. the 255 40 17s on advan rc2s with 45 offset and -2.5 camber fit in the front but in the rear fenders need to be rolled and a 5 mm spacer might be needed. but regardless it is more work than just looking at the tires and putting them on. 1 more thing, 255 40 17 might be too big for a 8 inch rim.
hope this sheds a little light
Jarrett
wopdeeze is offline   Reply With Quote
Old 12-22-2008, 10:16 PM   #3
EdHilario
Member#: 137398
2004 Impreza
I would say 245
EdHilario is offline   Reply With Quote
Old 12-22-2008, 10:28 PM   #4
Blown95ImpalaSS
Member#: 87629
size mostly depends on the brand/model of tire. 225/45/17 re070s run as wide as some 245s, while some 255 series tires run like a small 235.
which tires are you looking to purchase? the htechs are not super low so you shouldn;t have a rubbing problem with most tires that can fit on a 17x8 rim.
Blown95ImpalaSS is offline   Reply With Quote
Old 12-23-2008, 12:20 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
stop making new threads
Old 12-23-2008, 01:21 AM   #6
njwrx10
Member#: 169265
2011 STI
Wow, do you have nothing else better to do then to shoot people down?
Im trying to learn here so stop interfering
The offset is 48mm
Tires: Yokohama S-Drives
Thanks to the people who are helping and have helped
Old 12-23-2008, 01:41 AM   #7
Airborne_J
Member#: 93045
2004 FXT 5mt
2001 2.5 RS
+1...
Oh, and why do people buy tires based on look? What size are you currently running? If you're currently on 245's and you feel they don't track well, they're heavy and your gearing is affected too much, then you shouldn't go any higher. I would recommend going w/ the 245/40's. You don't want to spend $600 some bucks with the risk of rubbing.
Airborne_J is offline   Reply With Quote
Old 12-23-2008, 01:44 AM   #8
njwrx10
Member#: 169265
2011 STI
Thanks for your input.
Old 12-23-2008, 02:59 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
the search button is your friend
a board moderator may interfere MORE by telling you the same ****ing thing, as this same damned question has been asked hundreds of times here and the answer has not and will not change
search a LOT more
make new threads after you cant find your answer and that means FAR fewer threads
Old 12-23-2008, 03:25 AM   #10
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
I would recommend only going up to a 245/40/17 tire on a 17x8 +48 Rota Torque's. 255/40/17's would be better suited for a 17x9 wheel.
-Dan
suby_dude is offline   Reply With Quote
Old 12-23-2008, 04:13 AM   #11
subaruNV
Member#: 154549
2006 DOM 3 Powered
WHITE/ EQ Tuned 350Whp
285...Ken Block status!!!!! >:-)
subaruNV is offline   Reply With Quote
Old 12-23-2008, 11:52 AM   #12
njwrx10
Member#: 169265
2011 STI
Thanks everyone
WTB: Used race tires 255/40/17 or 245/40/17 ninefourteener Private 'Wanted' Classifieds 3 03-31-2010 12:53 PM
WTB: 225/45/17 or 235/45/17 or 245/40/17 TestaRossa SCIC Private Classifieds 8 03-19-2010 01:11 AM
WTB: 235/40/18 or 245/40/18 Tires 5230EVO SCIC Private Classifieds 6 06-13-2007 08:40 PM
WTB: 235/40/18 or 245/40/18 Tires 5230EVO Private 'Wanted' Classifieds 2 06-04-2007 09:32 PM
245/45/17 or 245/40/17 what do you think? kg2128 Tire & Wheel 6 01-06-2006 02:37 AM
