Old 03-30-2002, 08:29 PM   #1
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Question Do I have to remove the IC to get the turbo heat shield off?
Anyone know? Is it possible to either slide it down or work some other tricks to get it off without messing with the intercooler?
Thanks,
Paul
Snowphun is offline   Reply With Quote
Old 03-30-2002, 09:05 PM   #2
justinm
Member#: 15142
2002 WRX Wagon
Vishnu Stage2 Silver
Just go for it - get the IC outta the way, it's really not hard. The most difficult part is getting the IC y-hose back on the turbo upon reinstallation.. everything else is a piece of cake.
justinm is offline   Reply With Quote
Old 03-30-2002, 09:09 PM   #3
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
NO you do not need to take off the IC to take the heat shield off.
djerickd is offline   Reply With Quote
Old 03-30-2002, 09:16 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You probably don't have to as long as you have the tools to get to all the bolts that hold the heat shield on. However with the IC out of the way it's much easier to work in there.
Old 03-30-2002, 09:33 PM   #5
syntrix
Member#: 9211
2002 wrx wrb
swankmonkey.com
you can remove it without taking the IC off. I did that a few days ago, and I'm going to put the sheild back on tonight!
syntrix is offline   Reply With Quote
Old 03-31-2002, 12:04 AM   #6
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
So for those of you who took the shield off without moving the IC, what's the trick? I have all the bolts out of the shield, but can't seem to get it out of there.
I'd like to get it off so I can soak the DP bolts a few times before replacing the exhaust.
Thanks,
Paul
Old 03-31-2002, 12:08 AM   #7
syntrix
Member#: 9211
2002 wrx wrb
swankmonkey.com
make sure you get ALL the bolts, there's a lot of them and I missed one and the sheild would not come off!
Once you get them all it should lift straight up and then tilt towards the firewall.... then lift up again and it's out.
Old 03-31-2002, 01:38 AM   #8
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
The tough bolts are deep underneath. I only use four on mine now (took it off to polish it), and it is rock solid. You may need to soak the bolts in something.
Conduit is offline   Reply With Quote
FS: (IL) TDO4, Spt Turbo Heat Shield matt107 MWSOC Private Classifieds 8 06-10-2010 12:36 AM
FS : (IL) Spt Turbo Heat shield matt107 Engine/Power/Exhaust 5 06-08-2010 01:43 PM
FS Sti Exhaust, CAI extension, Sti IC Y Pipe, Turbo Heat Shield wrxroberts Engine/Power/Exhaust 5 05-03-2008 08:11 PM
How to get the heat shield off? bizkit642 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 01-20-2005 06:59 PM
Know were to get turbo heat shield? david2z4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-22-2001 12:13 AM
