Old 12-22-2008, 08:16 PM   #1
omeskcus
Member#: 134657
Default How to Disconnect AWD
Ok I have a 93 Impreza and Im trying to elimnate the sound I have coming from the rear of the car. Is there any easy to make the car FWD or so the back diff is not spinnning or working. Im trying to tell if I have noise coming from the diff.
I have heard some people talk about something to do with a fuse?
omeskcus is offline   Reply With Quote
Old 12-22-2008, 10:28 PM   #2
jeffg
Member#: 2958
2001 WRX (GC8)
Do you have a manual or automatic transmission?
If you have an auto, you can put a fuse in an empty slot in the fuse box to tell the center diff to put all the power to the front. The rear diff will still turn as its still connected to the wheels, there just wont be any engine power going to it.
If you have a manual transmission you are kind of SOL as it will take a welded center diff and removing parts to make this work.
jeffg is offline   Reply With Quote
Old 12-23-2008, 12:30 AM   #3
gregp07h4
Member#: 156770
2007 impreza 2.5i
urban grey metallic
unbelievable....if you wanted a FWD car you shoulda bought a civic
gregp07h4 is offline   Reply With Quote
Old 12-23-2008, 01:31 AM   #4
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
No kidding..
I see converting it RWD.
How come you can't just get it fixed rather than trying to convert it to FWD?
Smoke is offline   Reply With Quote
Old 12-23-2008, 01:47 AM   #5
Ioku
Member#: 164864
95 Impreza coupe
I dont think he whats a fwd car hes just trying to isolate were the noise is coming from.
Ioku is offline   Reply With Quote
Old 12-23-2008, 04:20 AM   #6
nivlem
Member#: 137488
2005 Saabaru 92 x
I've heard that one click of the ebrake shuts down the rear wheels, i have not tried this though.
nivlem is offline   Reply With Quote
Old 12-23-2008, 09:23 AM   #7
omeskcus
Member#: 134657
Whats unebelievable is that you can read!!! hahah lol
You should read my post before you make a dumb comment such as this kthnxbye
Old 12-23-2008, 09:24 AM   #8
omeskcus
Member#: 134657
Originally Posted by Da-Risin-Smoke View Post
No kidding..
Im not even saying my diff is bad im trying to eliminate where the sound from the rear of the car is coming from! Im not trying to CONVERT anything!!
Old 12-23-2008, 09:25 AM   #9
SUBASCOTT
Member#: 123421
its your rear wheel bearing
SUBASCOTT is offline   Reply With Quote
Old 12-23-2008, 11:36 AM   #10
omeskcus
Member#: 134657
thats what im thinking i just wanna be positive before i spend the money for the bearing
Old 12-23-2008, 03:33 PM   #11
VIsubi
Member#: 187834
06 2.5i impreza
Red
good point no argument here...question answered...I too agree with bearings cause if it was your diff you'd just drain the oil check it and add fresh royal purple diff oil..good to go!!!!
VIsubi is offline   Reply With Quote
how to disconnect daylight driving lights but have low beams? scoobypuff Interior & Exterior Modification 25 04-19-2010 10:09 PM
Confused on how to disconnect throttle cable.. jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-28-2005 04:12 PM
How to disconnect factory clutch wiring to wire UTEC LC wrxpeed Engine Management & Tuning 3 05-25-2005 03:24 AM
HELP!! How to disconnect E-Brake cable dcgear Brakes, Steering & Suspension 3 12-20-2002 02:29 AM
How to disconnect the day time running lights gldenchld Interior & Exterior Modification 2 12-01-2002 02:57 PM
