Old 12-22-2008, 10:29 PM   #1
grafton
Member#: 187936
07 WRB STi
Default weird temp gauge behavior
Today on the way home from an inlaws place in 17 deg weather i noticed weird behavior out of the temp gauge, the motor was warming up normally, so i thought, but when i hit above 3500rpms the temp needle dropped like a rock almost strait to C well let the car coast with the clutch pushed in letting the car idle as we cruised along, and the temp gauge started rising. after that i down shifted and ran the motor @ appox 4200 rpm and again the temp needle dropped ,
even took it on the interstate, as long as the revs are below 3500 then the temp gauge warms up to normal operating temp but run it above that and the needle starts to drop and the air blowing from the heater feels like it is not as hot when the needle drops
also when we got home i checked the motor, nothing looked off, the alt. was too hot to hold my hand on without feeling discomfort the upper radiator hose was a little firm with pressure but the entire radiator was cold to the touch
bad rad cap? bad themostat ( the motor heats up *but not overheating at all* below 3500 rpm but not above) bad radator ie. clogged?
grafton is offline   Reply With Quote
Old 12-22-2008, 11:37 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Did you check your coolent level?
And I would just replace the thermostat STAT with an OEM.
Old 12-23-2008, 01:12 AM   #3
grafton
Member#: 187936
07 WRB STi
seeing as thats a cheap repair i'll grab one while in advance tomorrow see if that fixes my odd issue never have seen something like this, last time i saw a broken thermostat it would take FOREVER to heat up on my 86 nissan pick up but once it was finished it wouldn't dip down with high revs
think it is possibly stuck partway open?
Old 12-23-2008, 07:43 AM   #4
Guerice
Member#: 51519
2006 2.5i Wagon
AKA Drtywgn
Had the same problem, the coolant temp sensor is at the top of the engine. So if your missing coolant or dropping some, and airlock will occur around the sensor and thus the sensor wont read right and will frig up your idle.
Guerice is offline   Reply With Quote
How to modify the stock dummy water temp gauge to real water temp gauge? SuperTurbo Normally Aspirated Powertrain 14 02-01-2008 06:38 PM
Is it possible to use a Water Temp Gauge as Intercooler Temp Gauge ? Sausage Electrical & Lighting 6 12-11-2006 01:35 PM
trying to find air temp gauge. before-after intercooler air temp, and two others STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-10-2003 03:38 PM
Transmission temp gauge idea, Switch to use coolant temp gauge so no dash space taken ciper Transmission (AT/MT) & Driveline 6 06-05-2003 03:54 PM
Weird oil temperature gauge behavior Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-01-2002 06:32 PM
