Old 12-23-2008, 04:21 PM   #1
subie_hatch84
Member#: 193131
2008 Impreza 2.5i
Dark Grey Metallic
Post Lightening a stock flywheel.
This is more of a research post than anything else. But does anyone have any info. or experience working with the transmissions from the '08+ impreza? I am looking to lighten things up for efficiency.
I was wanting to get a stock flywheel from another impreza; possibly used, maybe from a junker (not that finding an 08+ junker would be easy), and machining a few lbs off of it and swapping it out.
Am I just having a pipedream? Is this going to be more trouble than it’s worth / or do any good on a stock N/A motor right now? Also, does the 08 model run the same transmissions as previous imprezas so I might have an easier time finding one?
thank you!
subie_hatch84 is offline   Reply With Quote
Old 12-23-2008, 11:45 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I'm pretty sure that at least 3-5 companies make a LW flywheel for your car. For the price of machining and balancing a stock flywheel just to save a few pounds, you could, more than likely, buy a LW flywheel.
I dont think it would be worth it, but i've been wrong before...
~Josh~
What do you think if I used a brake lathe to lighten a stock flywheel ciper Transmission (AT/MT) & Driveline 12 08-06-2008 03:04 AM
2.5 Hybrid, lightened or stock flywheel? SAIKOU Built Motor Discussion 6 10-24-2007 05:09 PM
lighten stock flywheel Casperwrx Transmission (AT/MT) & Driveline 1 04-01-2003 04:19 PM
need help with lightening of stock RS flywheel couldnthinkaone Transmission (AT/MT) & Driveline 8 05-14-2002 03:27 PM
Where can I get a stock flywheel lightened and balanced? dbrown Normally Aspirated Powertrain 0 08-03-2001 11:12 PM
