#1 |
Member#: 192866
Vehicle:2006 Impreza Blue |
Read that the ends could be cut off of the stock injectors to yield aprox. 750 CC. Using a T3 60 trim Turbo my questions are:
1) How does removing the end effect the spray pattern 2) Can they be tuned easyly using the Greddy Ultimate 3) Will they run to rich at Idel and lower RPMs 4) Are they worth doing or just get a set of WRX top feed injectors
#2 |
Member#: 175483
Vehicle:97 N/A w/ MS3 Aegean Blue |
I thought that WRX or STI injectors were the ones that you could modify.
#3 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
You can mod any injector I would imagine. IIRC, the stock RS injector is 270cc/min. Yes it effects the spray pattern. The Emanage should allow you to pull fuel at idle to run normally. I would look into sending your injectors (or buy a second set) to Deaschwerks (sp?) to be modified. Then weight that cost vs. buying a set of used wrx 440's.
~Josh~ |
#4 | |
Member#: 2279
South East
Vehicle:2000 Slingshot/99RS Pastelito Racing / SFSOC |
![]() http://forums.nasioc.com/forums/showthread.php?t=478921 |
#5 |
Member#: 192866
Are you saying the stock top feed RS 2.5 injector can not be modified? If you can modify them what would the CCs be and would it be the same procedure?
#6 |
Member#: 2279
South East
I've never heard of anyone modifying the stock RS injectors. I modded and am running the WRX ones, and came back from RC Engineering flowing at ~830cc. Some have gotten ~870cc out of them.
#7 |
Member#: 141232
NESIC
Vehicle:95 wrx kinda blue |
I have modded 2 sets, they are just under 550cc's.
I sent them to be flow tested ,and came up with 1 matched set. |
#8 |
Member#: 192866
550 CCs out of a stock set. 550cc's is just about were I want to be. I will be running 8# max boost. Did you just grind the end off? You stated it took you 2 sets to get one good set? How far were they off?
#9 |
Member#: 86995
Vehicle:2005 Tacoma |
Yea please share, I have 2 sets of these sitting in a bag.
#10 |
Member#: 93364
RMIC
Vehicle:1998 Impreza RS-T 22 SM |
#11 |
Member#: 39936
Vehicle:99RS TWE&SCAT EJ257 Hydra+HMist+PPG+35R=DEATH |
my friend and i tried drilling them with a jewelers drill and a jeweler who was really good.... we got no where lots of leaks etc
just do the wrx mod |
#12 |
Member#: 36333
NESIC
Vehicle:DIY project: life I need more TIME! |
IIRC the only "easy" way to mod the injectors is to use wrx top feeds. The yellowtop sti injectors are doable...but harder. I plan to send mine off to PE to mod , its pretty cheap too.
| Thread Tools | |
| Display Modes | |
| WTB: Perrin Modified stock sit injectors! | explicithero | Private 'Wanted' Classifieds | 0 | 03-14-2007 06:13 PM |
| MD: Modified Stock WRX injectors | lowblow | Private 'For Sale' Classifieds | 37 | 11-20-2005 04:34 PM |
| Modified stock 740cc injectors | Kegger | Private 'For Sale' Classifieds | 6 | 02-16-2005 04:24 PM |
| need link on how to modify stock wrx injectors | moorebl | Factory 2.0L Turbo Powertrain | 1 | 11-26-2004 08:26 PM |
| Perrin is modifying stock sti injectors? | Rickyh | Engine Management & Tuning | 1 | 02-12-2004 09:45 AM |
