Old 12-23-2008, 08:35 PM   #1
Suberman
Member#: 82487
2007 WRX STI Spec C
Default DCCD flashing, VDC & Hill assist lights on?!?!
Hey guys, I got myself a JDM 13:1 RHD steering rack, ALk and bushings (which i will give my impression later on). Installed by a very reputable workshop.
After the installation of the rack, the DCCD lights were flashing, VDC & hill assist lights were on.
Mechanic said most probably the steering angle sensor needed recalibration.
So i went to the dealership to get it checked out. They killed my warranty period because of the ALK i fitted (which was going to end in 3 months anyway)
Long story short, they said the switch combination is damaged and needed to be replaced. Part # 83113FG010
What is a switch combination? What does it do? I know its the piece that the wiper and lights switchgear attaches to. I think its also called steering wheel roller connector? As it shows in the invoice.
Prior to this, i had a curbing incident that left me with a bent LCA and curbed all 4 wheels. But There were no problems before the quick rack.
Could the installation have something to do with it? Let me hear your thoughts.
Suberman is offline   Reply With Quote
Old 12-23-2008, 09:27 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
If you went to the dealer and they found out what was wrong why are you asking us? You go to a dealer, they find the fault, they fix it, you pay....that's how it's supposed to work. If you have questions, ask them as we are 17,000 miles away from you and have NO IDEA what the problem is or how to help.
Old 12-24-2008, 06:39 PM   #3
stiwrcaz
Member#: 55056
2002 OPEN class 34mm
yellow #356
actually it is a simple mistake that your installer made,they had the rack disconnected from the steering colum and turned the steering wheel to far,there is a spiral spring that went to far one way and broke,the spiral spring has wires in it for the air bag and angle sensor. i would try and get the install shop to cover the cost to repair,it is there fault.
stiwrcaz is offline   Reply With Quote
Old 01-02-2009, 04:08 PM   #4
scubyslacker
Member#: 44124
2008 STI
Hey, I have the same problem after I installed a set of steering rack bushings and now all the same lights are flashing on my 08 sti. Aside from from some steering notchyness, I'm guessing I also broke the spiral spring with all the sensors in it. Is it safe to drive my car cautiously for a short period if this is in fact the problem?
scubyslacker is offline   Reply With Quote
Old 01-12-2009, 05:18 AM   #5
s204life
Member#: 180169
2k2 WRX WAGON SILVR
08 S550 AMG Blk/Blk
Why would you change bushings on practicly brand new car? and no there is no problem driving it like that, the only thing is that your dccd in open all the way witch means you have more traction in the rear then in the front, unless you lose control of the vehicle it would be more like a 100% rear wheel drive. go to the dealer and sort it off
s204life is offline   Reply With Quote
Old 01-12-2009, 11:20 AM   #6
RafalW
Member#: 8193
2008 WRX STI
This is wrong. It always gives 41:59 torque split with an open DCCD.
RafalW is offline   Reply With Quote
Old 01-13-2009, 01:59 AM   #7
s204life
Member#: 180169
2k2 WRX WAGON SILVR
08 S550 AMG Blk/Blk
oh yeah... take off hard with your dccd open all the way on a one way street when its snowing and let me know what you found out. or take a curve at 20mph so you can see what wrong really is.. and you guys are suppose to be the so called "specialist". do your homework buddy.
Old 01-14-2009, 07:55 PM   #8
bertune
Member#: 107290
Actually the 08' has a spiral spring (clock spring) separate from the steering angle sensor. The steering angle sensor doesn't have anything inside of it to break like the spiral spring. There should be someway to calibrate the angle sensor........which i would love to know HOW!!
bertune is offline   Reply With Quote
Old 01-14-2009, 08:14 PM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Um...he's right. The torque split is 41 front 59 rear. This cannot be over come as it is the mechnical limitation of power transfer that the center diff can perform. The 05+ sti can go from 50/50 to 41/59. It will lever send anymore power to the rear.
Old 01-14-2009, 10:09 PM   #10
bertune
Member#: 107290
someway to calibrate the angle sensor ???????????
Old 01-17-2009, 09:49 AM   #11
s204life
Member#: 180169
2k2 WRX WAGON SILVR
08 S550 AMG Blk/Blk
Not the stock one.. I dont know about the aftermarkets tho.
Old 01-20-2009, 01:59 PM   #12
bertune
Member#: 107290
Old 01-20-2009, 02:03 PM   #13
atomicfire
Member#: 136296
2005 STi
05 STi is 35/65
atomicfire is offline   Reply With Quote
Old 01-21-2009, 03:46 PM   #14
RafalW
Member#: 8193
2008 WRX STI
I am not sure what you mean here. Relative speed of wheels are not in any way indicating that you are getting 100% of torque to ones which spin quicker.
In 08 STI with an open DCCD you always get 41:59 split regardless of traction on any of the wheels. It still means that a car can power oversteer under some circumstances like you describe.
09 WRX-VDC, ABS, and Hill Assist Warning Lights Subirex09 Warranty Issues & SOA Problems 47 09-07-2015 03:12 PM
VDC and Hill start assist warning lights on docsmitty Service & Maintenance 19 10-31-2011 02:20 PM
09-10 wrx abs,traction,hill assist lights felya589 Newbies & FAQs 3 03-26-2010 05:53 PM
Traction Control Light and Hil Assist Light On kwanjie Brakes, Steering & Suspension 2 05-26-2009 09:56 AM
08 WRX: Hill hold, ABS, & Traction Control lights on dash Shohin General Community 7 01-23-2009 08:56 AM
