Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 12-24-2008, 10:31 AM   #1
201Motorsports
Vendor
Vendor Sales Rating: (37)
Member#: 121809
2003 Evo VIII
Default The 201 Motorsports "There's A Defi & AEM Price Increase Coming 01/01/09" Sale
Defi & AEM Gauge Sale @ 201 Motorsports
It's true! The prices for all Defi gauges will be increased significantly on January 1, 2009. AEM will be returning their UEGO wideband gauge to its regular, higher pricing point as well. Grab your gauge packages now!
__________________
[b]Phil
[COLOR="SeaGreen"]201 Motorsports[/COLOR]
[COLOR="SeaGreen"]Email[/COLOR]
phil[at]201motorsports.com
[center]
[/b][/center]
201Motorsports is offline
Old 12-24-2008, 10:31 AM   #2
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Defi Red Racer, White Racer, and Blue Racer Gauges @ 201 Motorsports
No Control Unit Needed!!!
Exclusive gauges for the USA which are derived from quick-responsive and high-accurate Defi analog gauges.
* Stepping motor "STEP MASTER VS-2" provides smooth operation
* Ignition ON initiates self-luminescence gauge
* Red illumination using high-brightness LEDs
* Full 270 degrees sweep dial provides ultimate visibility
* A mounting bracket and instrument case is provided with the product
* The red triangle of the regular position bezel can be used as a warning indicator
* Does not require the Defi-Link Control Unit for use (Blue Racer Gauge cannot be connected to the Defi-Link System)
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
Sensor disconnection check:
This function reports any in-proper connections, broken or disconnected sensor or sensor wire. The pointer will wave between 250 and 260 degrees.
Short-circuiting check:
This function indicates any short circuit on the sensor or sensor wire.
__________________
[b]Phil
[center]
[/b][/center]
Old 12-24-2008, 10:31 AM   #3
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Defi BF Imperial Amber and White Gauges @ 201 Motorsports
Imperial
Defi-Link Meter BFs are electronic blacked out gauges which are high response and refined design. When the car is off they have a black face with no numbers on them. As soon as the car is turned on, the gauges light up and are in full affect.
Defi-Link Meter BFs need to be connected to Defi-Link Control Unit II. Up to 6 gauges can be connected and controlled by one Control Unit II. The name of the connection system is "Defi-Link System." Defi-Link System allows gauges to be attached to Defi-Link Control Unit II with a single "DAISY CHAIN" wiring system.
Control Unit II: $107 shipped
Defi BF Imperial Amber 60mm Gauges
Boost: $210 shipped
EGT: $245 shipped
Fuel Pressure: $245 shipped
Oil Pressure: $245 shipped
Oil Temperature: $184 shipped
Water Temperature: $184 shipped
Defi BF Imperial White 60mm Gauges
Boost: $210 shipped
EGT: $245 shipped
__________________
[b]Phil
[center]
[/b][/center]
Old 12-24-2008, 10:32 AM   #4
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Defi BF Amber and White Gauges @ 201 Motorsports
Metric
Defi BF Amber 60mm Gauges
Boost: $210 shipped
EGT: $245 shipped
Defi BF White 60mm Gauges
Boost: $210 shipped
EGT: $245 shipped
__________________
[b]Phil
[center]
[/b][/center]
Old 12-24-2008, 10:32 AM   #5
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
AEM UEGO @ 201 Motorsports
AEM UEGO Wideband O2 52mm Gauge
This is a six-in-one gauge-type UEGO controller.
AEM’s Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
No laptop required for monitoring!
Key features of the AEM Gauge-Type UEGO Controller:
* 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda (11.0:1 to 17.0:1)
* Integrated three-digit display reveals AFR or Lambda in real time (10.0:1 to 18.5:1)
* User-selectable 0-5v analog output included for use with data loggers and most programmable engine management systems
* Switch between AFR or Lambda readout with a twist of a switch (included face plate change is required for proper readout)
* Included black and silver bezels, black and white AFR gauge faces and black Lambda gauge face allow you to personalize the look of your gauge!
* Quick-Connect system eases installation by allowing users to mount the gauge and sensor wiring separately
* Ideal AFR monitoring tool for carbureted applications and engine dynamometers
* Does not oscillate AFR like narrow band sensors
* Serial data stream included for output of AFR (RS 232)
* Accurate to 0.1 AFR
* Bosch UEGO sensor included
Price: $218.11 shipped
__________________
[b]Phil
[center]
[/b][/center]
Closed Thread
Gauges @ 201 Motorsports - AEM / STRI / Defi 201Motorsports Gauges & Electronics 35 12-01-2009 12:03 PM
AEM 2008 WRX/STi Cold Air Intake IN STOCK + 201 Motorsports $25 Rebate! 201Motorsports Engine/Power/Exhaust 18 03-02-2009 12:19 AM
201 Motorsports Interior Gauge Sale! Defi & AEM IN STOCK! 201Motorsports Gauges & Electronics 43 11-29-2008 09:38 AM
201 Motorsports Interior Gauge Sale! Defi & AEM IN STOCK! 201Motorsports Interior/Dressup/Audio & Security 20 08-23-2008 12:05 PM
APS is back in the United States! IN STOCK & FREE SHIPPING @ 201 MOTORSPORTS!! 201Motorsports Engine/Power/Exhaust 7 01-28-2008 01:22 PM
