Old 12-24-2008, 11:50 AM   #1
Hah72215
Member#: 77815
2002 WRX WAGON
Default Leakdown and Compression Test Results
Compression: 1)135 2)148 3)135 4)145
Leakdown: 1)18% 2)10% 3)16% 4)10%
I was told the leaks were all due to blowby through the rings which is pretty common.
My question is how much life do I have left? I'm at stage 2 with a full catless exhaust. I had the test done since I was thinking about a turbo upgrade, but at this point I figure I should leave things the way they are and just get a protune so that it runs as well as it can until it's finished.
Any advice? Thanks.
Hah72215 is offline   Reply With Quote
Old 12-24-2008, 01:05 PM   #2
centeno711
Member#: 184638
2002 wrx wagon wrb
97 cummins 1ton 4x4
if your gonna run it till it dies why not kill it with a bigger turbo?
it may not last as long but if you have it in mind to change out the motor anyways have some fun with it
centeno711 is offline   Reply With Quote
Old 12-24-2008, 01:24 PM   #3
BluScubi
Member#: 162726
2009 LGT
QSM
Your compression numbers aren't too bad. They're all within spec and within 10% of each other. Leak down numbers are a little high, but not too horrible tho. I believe less than either 10% or 15% leakage is considered acceptable. I can't remember which it is.
I'd get a protune either way. How long it will last with or without a turbo upgrade is hard to say.
BluScubi is offline   Reply With Quote
Old 12-24-2008, 01:35 PM   #4
Hah72215
Member#: 77815
2002 WRX WAGON
I'm close to 120,000 miles now and I was hoping to go at least 200,000. Maybe I'll just port the turbo and everything else for now and get a protune. Hopefully, this will give me some time to at least save up for a motor.
motor question - leakdown vs compression test jackdempsey Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 12-18-2009 05:20 AM
Where can I get a leakdown and compression test? jcbluescooby Tri-State Area Forum 13 05-21-2009 04:22 PM
can someone please explane Leakdown vs compression test? IllNastyImpreza Service & Maintenance 8 12-25-2008 01:57 AM
Cylinder Leakdown vs Compression Test Explained NITROS Service & Maintenance 3 02-13-2007 02:42 PM
Compression test results numbers Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-12-2001 01:08 AM
