Old 12-24-2008, 01:28 PM   #1
lazyjai123
Member#: 178538
Default v3 jdm sti swap injector problem
hi i have a v3 sti ej20k. everything is wired up but im getting a weak injector#1 ground pulse from the ecu to the injector. i checked the wire from ecu to injector and theres no resistance. anyone have a schematics for this engine?
any help would be good thanks
also the check engine light stays on. is there a way to read the trouble code its giving me?
lazyjai123 is offline   Reply With Quote
Old 12-25-2008, 09:15 PM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
what is the resistance of the injector
Old 12-27-2008, 04:27 PM   #3
lazyjai123
Member#: 178538
i've found the problem. it turns out that there was a wire that wasnt listed on the pin out that i had conncet for the atmosphere sensor, and iac sensors. thanks for everyone who have read this post
Indiana FS: v3 JDM STi tranny, 02 wrx heads, misc parts Feign MWSOC Private Classifieds 30 09-14-2009 08:55 AM
V3 Jdm Sti N8WRX Complete Car Part-Out 24 10-31-2008 03:13 PM
SoCal:STi injectors, JDM STi pink injectors and 05 WRX injectors BlueFish Engine/Power/Exhaust 19 11-24-2007 10:30 PM
SoCal:STi injectors, JDM STi pink injectors and 05 WRX injectors BlueFish Engine/Power/Exhaust 25 11-12-2007 04:36 PM
USDM WRX or STi swap harder than JDM STi swap??? garface Normally Aspirated with bolt-on Forced Induction Powertrain 4 01-12-2003 11:37 PM
Message Board Statistics All times are GMT -4. The time now is 09:12 PM.
